Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Faulty Fuse Holder causes Multiple Electrical Fault Messages
    Jan 2013
    Today I went to pick up my daughter from school. I parked at the school, quickly picked her up (10 mins) and then drove away. After 2 minutes of driving the following lights have stopped working in my Tiguan:
    - front right headlight
    - front right indicator
    - rear left indicator
    - rear middle break light
    - rear left fog light
    The indicator sound was quick and the error messages appeared on my MVD one after another: "Check front right..." and so on. WTH???
    After I arrived to my destination I confirmed visually that the lights didnt work indeed. I spent there an hour and then drove away again. Guess what? Everything was working again perfectly! WTH??? In the meantime, I called VW Service and booked the car in for next week Monday.
    FYI: my car had been serviced a week ago, they replaced my original factory installed GPS and radio aerial and re-ran the antenna cable from the head unit to the antenna.
    After that I had the flat battery on the weekend (NRMA replaced it) and today this strange electrical issue. Coincidence?
    I am not a car mechanic (just an engineer), but it seems like something is loose, maybe a ground wire?
    MY18 VW Tiguan Comfortline
    Mar 2013
    Brisbane QLD
    Your Ebox fuse board will have melted...the fuse box next to the battery...check the 30amp fuse on the back left...pull it out..you will see it and the board melted....put a new fuse in will get them working for now but you will need a new fuse board....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jan 2013
    Quote Originally Posted by vdubmotorworx View Post
    But it is working now. Cannot be the fuse loose?
    Dec 2009
    Canberra
    Had the same thing happen. It started with one fuse blowing which I replaced, then next time smelt something burning which was the fuse circuit board. Go see an auto electrician, cost me about $500 to fix and they checked that everything was grounded properly. just one of those
    Jan 2013
    Quote Originally Posted by 08elf View Post
    But what did it cause?
    Mar 2013
    Brisbane QLD
    have a check of the fuse mate...you will see if thats your issue..only takes 2 mins to check ...VDUB...
    Dec 2009
    Canberra
    It caused what you described, the car to reported that heaps lights had stopped working all simultaneously. It's the board. Fix that, problem solved.
    Jan 2013
    I am sorry to be pain in the ass but that's the effect not the cause. What causes a fusebox melt?
    Mar 2013
    Brisbane QLD
    Think its just a issue the board itself...as after replacing the board ive not seen one melt again so points not to being a outside issue just proberly manufacturing issue of the board that fails over time..
    Jan 2013
    Thanks vdub. This sounds pretty bad. I love my car, but I have never ever had any fuse problem with my 10 previous cars I drove. Especially not after 3 years and 5 months, just when the warranty expired. I would not expect something like this from VW, but again this is my first VW, before I drove Fords, Fiat, Nissans, Hondas.
    BTW I checked the fuse box and the top left fuse (green 30) have melted just like you said.
    Do you know what that fuse is for?
