Originally Posted by
Tiggy1
From one "grumpy old fart" to another - if that would correct the problem I would - duh
Not the spring travel, more the rate - Eibach progressive rate springs have improved the "low impact/small bump" ride whilst giving better handling and lower CofG (the desired effect), but am trying to insulate the car more from small bumps and ripples that are rife on our roads (lucky to have 1km which is the same road surface - patches on patches). I know I'll never get rid of it altogether, just trying to tone it down as much as possible
The rate is what concerns me - the "soft" portion of the springs are probably close to being coil bound with just the vehicle weight (else the vehicle would take a big "set" on corner entry) so you would only get the softer ride for quite small bumps and then you are in the stiffer portion of the springs where you are also underdamped, giving a jouncy ride.
Smaller wheels with taller sidewalls aren't a bad option, though - not many here would take that step.
Resident grumpy old fart
