Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Exchange 18" Wheels for 17" - any takers?
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Tiggy1 View Post
    From one "grumpy old fart" to another - if that would correct the problem I would - duh
    Not the spring travel, more the rate - Eibach progressive rate springs have improved the "low impact/small bump" ride whilst giving better handling and lower CofG (the desired effect), but am trying to insulate the car more from small bumps and ripples that are rife on our roads (lucky to have 1km which is the same road surface - patches on patches). I know I'll never get rid of it altogether, just trying to tone it down as much as possible
    The rate is what concerns me - the "soft" portion of the springs are probably close to being coil bound with just the vehicle weight (else the vehicle would take a big "set" on corner entry) so you would only get the softer ride for quite small bumps and then you are in the stiffer portion of the springs where you are also underdamped, giving a jouncy ride.
    Smaller wheels with taller sidewalls aren't a bad option, though - not many here would take that step.
    Resident grumpy old fart
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by kaanage View Post
    Could be, but initial impression is that the Eibachs give better bump absorption (on smaller stuff anyway) - could be in trouble if I go offroad and hit any bigger bumps though
    Hoping the higher tyres would give more cushioning though. Guess I'm pushing s*&t uphill a bit, but coilovers might be only true solution (sigh)
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    Jul 2010
    Excellent - well done. Definitely the second ones look better on the car, just not sure about the gunmetal colour (you're right again Aussietig)
    Would look grouse with your peppergray though Tigomatic
    Any chance Tigomatic can photochop these for you also?
    MY11 Tiguan 147TSI (SOLD)
    Oct 2010
    Melbourne, VIC
    The taller tyres will definitely help - I downsized an inch for my daily tyres after fitting a B12 kit to return some cushioning.
    A good set of dampers would go well with those springs - you don't have to go the coilover route for better damping.
    Sep 2011
    Townsville, Nth Qld
    Yes, am regretting now not going the extra expense and getting shocks as well - was considering Koni FSD, but a few people on reviews and Ian at Rennenhaus have said that they had trouble with them failing. Koni Yellows (sports adjustable) might be a better bet though. If I flog it enough I might be able to wear out original shocks quick enough to justify getting them
    I guess you're right about coilovers - not going racing and probably not savvy enough to set them up right anyway
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by aussietig View Post
    You're a bad influence Aussietig
    All in my spare time. RS6 rims look good too!
    http://i1077.photobucket.com/albums/...iggyTyres3.jpg
    MY12 103TDI 4MOTION: - DSG | Pepper Grey Metallic | Comfort Pack | RNS510 Sat Nav + RVC | Park Assist 2 | Front Fog Lights | Chrome Exhaust Tips - Canberra, ACT
    Jul 2010
    Great stuff Tigomatic!
    Yep ... they're the ones for you Tiggy1!
    Thanks aussietig! They're definitely the ones for Tiggy1. What do you reckon Tiggy1! …not that we are pushy or anything.
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by Tigomatic View Post
    Sigh - you guys
    They do look pretty good though - you willing to clean them for me?
