Finally the new Tiguan is here.....
I upgraded both front and rear sway bars with Whiteline bars on Tig1. If I was to do it again I'd probably only do the rear bar as it gives the biggest bang for buck. The stock rear bar is quite flimsy whereas the front bar is already reasonably substantial. Also the rear bar is a DIY on the driveway job compared to the front bar which needs to get done in a workshop on a hoist.
I had some fitment issues with the Whiteline front sway bar, though I'm sure these have been sorted. Superpro also do sway bars for the Tiguan and I know a few people have installed these.
2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit!(FAMILY CAR)
2014 F30 328I (ME CAR)
2011 E46 330CI (SOLD)
I must say, im not quite sure what to think just yet...
TIGR
2017 162TSI R-Line Tiguan - Tungsten Silver | DAP | APR Stage 1 Build thread: https://goo.gl/YNgixR
2015 155TSI R-Line Tiguan - Build thread: https://goo.gl/sEqISR
First VCDS attempt to fix a lighting error code.
The story is I changed the Licence plate bulb to canbus free LED bulb and it come up with error code. After reading through a lot of forum and trial this is how to do it:
* Go into module 09-Central Electronics
* Then Long Coding Helper
* Go to Byte 18
* Tick "License Plate Lighting w/o Pulse Width Modulation (PWM) [LED Lighting]"
* Do it!
Also on the way out you can then clear the DTC.![]()
Hi Evilz, where did you get the aluminium cover for the resting foot pedal? Thanks.
It been awhile, how is everybody?
Just a quick question, how often does the Tig need a service? Currently the car need an oil change on every 3500km (i only done 6500km so far) is this normal?
Even using VCDs the max i know how to reset it is 3500km limt....... any thought to get it?
Service should be every 12 months/15,000km depending on what comes first.
Can anyone please advise on re-setting the service advisory via RossTech VCDS - mine is coming up months earlier than it should?
I have tried the ignition on whilst holding the odometer down which does bring up the cancellation warning but selecting OK has no effect.
it's a 2013 R Line.
Dingah
