Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 106
Thread: Evilz 2015 Tiguan 155TSI R Line
  1. #41
    Sep 2012
    Cairns, QLD
    Are those replacement mirror panels? Whereabouts did you get them?
  2. #42
    Quote Originally Posted by Evilz View Post
    Has anyone try to install front door puddle/Warning lights?
    Door warning lights yes done to Tig1. It's a very easy mod - get all the bits from bold-sport: Bold-Sport.com :: Door Warning Lights Housing
    Just requires a simple bit change in the coding and you're done!
    I haven't done the mirror puddle lights but these will be very similar to the Mk6 Golf: Bold-Sport.com :: Mirror LED Puddle Light Housing - Golf VI
    There's a DIY for it if you search on Google but does require cutting out the bottom of your mirror housings so is not reversible....
    Feb 2015
    Sydney, Australia
    Quote Originally Posted by Fred Nurk View Post
    Hi Fred, i got this from here ( OEM Decorative Covers of Side Mirrors VW Tiguan and Skoda Yeti - ALU look for 50.00 € - Body Parts ).
    This site is given by SciroccoJ. : )
  4. #44
    Feb 2015
    Sydney, Australia
    Hi Tigger73,
    DIY found, wil try to do the warning lights for the doors this weekend for now. Seem like the puddle light will require alot more work in cutting and installation time. Got a big weekend ahead of me, gona get the Tig tint and if possible APR tuning as well. : ) Will update you guys later.
  5. #45
    Feb 2015
    Sydney, Australia
    Finally got time to upload some of my new Tig photo.
    This is from last weekend when i pick up my car, till now still haven't got much of a chance to drive it. Anyway will get some more proper photo this weekend after the tint and other mod.
    Attached Thumbnails Attached Thumbnails Evilz 2015 Tiguan 155TSI R Line-image1-jpg   Evilz 2015 Tiguan 155TSI R Line-image2-jpg
  6. #46
    Sep 2011
    melbourne
    any noticeable improvement with the airbox?
  7. #47
    Oct 2010
    Puddle lights can be purchased here: Online Shop OEM VW Sharan Tiguan rear-view mirror turn signal lights according to ambient light 5N0 949 101/102|Aliexpress Mobile
    Very easy install, only had a problem coding these puddle lights and door warning lights together. But I finally
    Figured it out and loving the light output, especially with led globes.
    You will also need replacement door clips.
  8. #48
    Feb 2015
    Sydney, Australia
    Are you sure it will fit into the 2015 tig? Also what sort of coding you need? I was trying to install the warning light for the door tonight, after taking it off then realise the wiring pin is double clip. Where it should be a single clip to fit in the connector, now i have to get some right clip wiring before installing it. Also can anyone tell me where i can source the VCDS/VAG software for coding please.
  9. #49
    Feb 2015
    Sydney, Australia
    Progress tonight.
    I have also installed the DV+ T9351, NGK Iridium IX (BKR7EIX) and R8 coils, speaking of which i totally forgotten to take to photo of it. . Also try to install the LED HID light headlight but failed, seem like there would be some rewiring and coding needed too. Just installing the headlight is easy, but i thought is plug and play..... which is not. Anyone got any ideas about this DIY?
    The airbox and wastegate only making minimal acoustic sound and performance wise i can feel that the car is definitely smoother and happier from start to high rev. But again i havent been driving it too hard (6k rev on testing after installation), since the pistons is still new and not run in yet. Im trying to get the tuning done on next week (if i can book in) and will see how much different it gona be after.
    Evilz 2015 Tiguan 155TSI R Line-image3-jpg   Evilz 2015 Tiguan 155TSI R Line-image4-jpg
    Evilz 2015 Tiguan 155TSI R Line-image5-jpg
  10. #50
    Feb 2015
    Sydney, Australia
    Just a quick update, after a long wait i finally done my list for now. I've got the APR and DSG tune at the same time and i can already feel the car is so much smoother on normal driving and really give it to you when you want to push it hard. The gear changes is definitely heaps better after the tune, at least i can change lane much quicker without lag. I'm sure most of you guys knows about the tune etc etc.....
    Other than that the LED DRL headlight with AFS is excellent and i absolutely love it, but still need to change all the lighting to a same brighter spectrum (maybe 8000k). Thought of using LED light bulb but it seem to be too bulky and cost too much. I have also done all the doors warning lights to be white LED, which give it more lighting when coming out to the dark. Also and of course the all the interior light to LED.
    The only thing i haven't change is the rego plate to LED, even i brought the canbus error free LED light it still give me the error warning on the dash........
    Final thing i did is the ABT partial kit, as it is the Tig R-line the only thing it could have is the quad exhaust and the front grill. I must say the exhaust doesn't give a load noise but a soild dull tone which i like. Will give it a go of the acoustic testing and the effectiveness of the slightly bigger exhaust when i can.
    Now im thinking of improving the handling of the car, such as sway bar for the front and rear, lower control arm and front strut bar. I have looked at it from HP and want to see what are the options out there. Has anyone got them on their Tig and any suggestion?
    Here is some quick snap shot and will take some proper picture when i can cope with my 4 months old.
    Attached Thumbnails Attached Thumbnails Evilz 2015 Tiguan 155TSI R Line-image-21-jpg   Evilz 2015 Tiguan 155TSI R Line-untitled-png
    2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit! (FAMILY CAR)
    2014 F30 328I (ME CAR)
    2011 E46 330CI (SOLD)
