Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 106
Thread: Evilz 2015 Tiguan 155TSI R Line
  1. #61
    Mar 2015
    Torrens ACT
    Nope - doesn't work.
    Please read my earlier post - ODO and ignition on brings up option, select OK but it doesn't work.
    Dingah
  2. #62
    Arrawarra
    Veering off topic here, sorry Evilz.
    When you choose OK, does it prompt: 'Do you really want to Reset'?
    With my (white MFD) 2010, with ignition on, MENU button (NOT ODO button) twice (once takes to radio stations), scroll down 8 clicks to SERVICE INDICATOR, 2 options are INFO & RESET. INFO tells you how long to go. RESET prompts you to confirm you do want to reset. I think i can choose YES or CANCEL. So if you choose YES, then have a look in INFO, it should say something like 'NEXT SERVICE DUE 15000kms or 365 days. ??
  3. #63
    Mar 2015
    Torrens ACT
    NO much simpler.
    Ignition on, holding down ODO and the Reset option appears as soon as you turn the ignition key.
    Options are OK or cancel.
    Scroll to OK and select and it seems to accept the command.
    Turn off turn on and warning still appears.
    Dingah
  4. #64
    Jun 2009
    Quote Originally Posted by Dingah View Post
    NO much simpler.
    Dingah
    That method is only applicable to the golf's from memory.
    You need to follow the method MGV posted to get the service interval to reset.
  5. #65
    Nov 2012
    Southern Bavaria
    Use VCDS to change the service interval, it will not reset the service interval
  6. #66
    Arrawarra
    NO much simpler...
    Did the slightly less simple procedure, but one that actually works, work out in your Tig, Dingah? Or still having issues?
  7. #67
    Mar 2015
    Torrens ACT
    Ha!
    When I get the time I'll VCDS it as facing west at high tide didn't seem to work either!
    Dingah
  8. #68
    Feb 2015
    Sydney, Australia
    Hows everyone?? It been awhile, recently my parent starting to look at the New Tig r line. Wondering the thought from everyone? Also ive been looking at installing a semi-floating disc kit (front & rear) for my tig, any suggestion from brand, size, #piston and thought. Ive been looking through many company but still yet to find a set for the back......
    2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit! (FAMILY CAR)
    2014 F30 328I (ME CAR)
    2011 E46 330CI (SOLD)
  9. #69
    Feb 2015
    Sydney, Australia
    Has anyone installed a "Wagner Tuning Intercooler" for their Tiguan or thought?
  10. #70
    Oct 2010
    Quote Originally Posted by Evilz View Post
    I have, don't do it unless you want to fabricate your own piping.
    Tiguan S3 Intercooler Install Guide
