Results 1 to 2 of 2
Thread: EPC problems
    Jan 2017
    israel
    EPC problems
    hi
    I have 09 tiguan ..5 weeks ago i got codes P0121 and P0221 ... I REPLACE the throttle body to NEW one .
    now i got the same codes again
    how this can happen?
    Jul 2007
    Brissy
    These codes relate to the accelerator pedal position sensors.
    Start with a check and clean the electrical connection on the accelerator pedal. Look for corrosion / green colour / powdery build up.
    Use electrical contact cleaner, MAF cleaner can be used if you don't have the electrical contact spray.
    From there perform output tests on the pedal using diagnostic cable / VCDS.
    OBD-II Trouble Code: P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
    OBD-II Trouble Code: P0221 Throttle Position Sensor/Switch B Circuit Range/Performance Problem
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
