Results 1 to 10 of 11
Thread: Engine oil refill
    Aug 2012
    Engine oil refill
    Hi all,
    Just bought my Tiguan 132DSG Petrol 2 months ago, have done around 3000km.
    This Morning the middle display showed "Check engine oil", so I pull out the dip stick, the engine oil was below minimum.
    As I need to go to work, haven't got time to refill. probly need to pick up some engine oil tonight.
    Not sure anyone else had this problem, Is this normal for a VW? Should I sent it back to dealer n get it checked?
    Arrawarra
    Maybe it was a little undefilled from day 1? Is this the 1st time you've checked it?
    I check mine every thousand... Has never required a top-up, tho I can see a little oil usage between 10000km changes ( about 3mm down from the high mark on the dipstick )
    Jun 2009
    I am guessing it was underfilled from the start.
    When i picked mine up they said to keep an eye on it as they can use a fair amount of oil in the first 5000km.
    So far I am on 20,000km and haven't had to top the oil up at all other than the yearly service.
    Dec 2008
    Sydney/Canberra
    I wont say it's normal as you've not hit the 15,000klms mark, and had it service yet.
    Get the dealership to top it up, and put it on record. Refuse to pay for the top-up, too
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Adelaide hills, SA
    I believe that it is still in the owner's manual and it was always a common sense to check the oil every 500km, it may shifted now to 1000km, but the driver is still required to check engine oil and others as mentioned in the owner's manual.
    As for the top ups, it's just fair to say that if you need top up after 3,000km it's OK and well within what is stated in the owner's manual. The VW dealers generally top up oil for free on the new cars, if you go there, but I think if you go to Jap dealer and demand the same, you could get some strange looks.
    Jan 2012
    Mine needed the refill at 5000km from new.
    Then again at 8500km.
    I think there is a oil burn issue with the new 132s.. Barloworld at five dock said it was 'normal'.
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by Umai Naa!! View Post
    Definitely do what Umai Naa says - NOT normal and have to use very specific oil, not any old Repco variety - stuff is freaking expensive too, so definitely go to dealer!
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    Dec 2008
    Sydney/Canberra
    What I was getting at is VW wont go down the path of oil consumption tests, etc, without it being serviced first. Baring in mind, the oil in the engine off the production line is not the same 504/507 oil used at servicing. Story goes, it's to aid running in, and more resistant to moiture contamination from the boat ride over here.
    Having said that, it's fine to top it up with 504/507.
    '01 Beetle 2.0
    Aug 2012
    Singapore
    This is a known problem with the 2.0t engines.
    Jul 2010
    From my own past experience, the engine tends to also burn more oil if you didn't take it easy and baby it during running in.
    MY11 Tiguan 147TSI (SOLD)
