Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: Engine oil
    Sep 2011
    Yatala
    How much oil needed for 103 tdi auto diesel?
    Just a quick question guys. 103 tdi auto, how much oil is meant to go in? Can't see it in the book??
    thanks in advance,
    Rich
    Adelaide hills, SA
    Exactly 4L.
    Sep 2011
    Yatala
    Exactly 4L.
    Thanks for that Transporter. Do you think the WC054 Cooper brand oil filter will be ok? They were pretty sure they're 'all the same'.. Not sure.. if you guys suggest something better I can take this one back no probs.
    Regards,
    Rich
    Just a heads up if you're buying oil:
    Repco has the Shell Helix Ultra Extra 5W30 (VW 507.00) on special for $52 for 5 litres. Sale on 29th Sept thru to 16th Oct. I made the mistake of buying the genuine VW stuff last time at $123+GST for 5 litres.
    Adelaide hills, SA
    Quote Originally Posted by majestic View Post
    Regards,
    Rich
    Don't risk it! I wouldn't use it in my engine if it was for free! The VW filter is the best and there is not a big price difference.
    Sep 2011
    Perth
    hello all
    Is the TSI also 4 L of oil? for a filter and oil change? or different?
    thanks
    Sep 2011
    Yatala
    Got the authentic VW oil filter coming today, $19.65. Pollen filter $32.55 which I was quite surprised by as Autobarn wanted $55 for an OEM one. $5.50 for the courier too!
    Thanks for your advice Transporter, I appreciate it.
    Erskineville, NSW
    Have found this frequently on the Skoda & the Golf before it. Some OEM consumables are pretty reasonably priced. IIRC, the Skoda oil filter is <$20 & the pollen filter similar. Aftermarket was about 50% more.
    Sep 2011
    Townsville, Nth Qld
    Hi all. Was of the same opinion, and was set to change oil after first 1000km, until service manager at VW dealership said NOT to, because VW puts special 10W monograde oil in at factory to help with run-in! Sounded good in theory so leaving mine until 10000km or so. Made the mistake of getting 5L of genuine oil without asking price first (eek!), so much better idea to use Penrite (as recommended by Transporter) or Castrol - was even a brochure in with owners manual stating which to use (Eco-something), and there is even Castrol on the filler cap, so I take that to mean Castrol is the same as genuine!
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    Erskineville, NSW
    Quote Originally Posted by Tiggy1 View Post
    So much fail at VW Servioce Centres
