No link between the two lights.
Best bet is to book it in to have a diagnostic scan, and go from there.
I just noticed this yellow warning light. It is steady on as I drive. Any reasons to worry?
My Tiguan is TSI 125, old fashion Auto, 2010 model. It has 55,000 km - last service at 50,000 km a year ago.
Interestingly, a few days ago - before the engine light started - I had a low oil light. The dipstick was showing Min, so I added 1/2 litre and it is now midway between Min and Max.
Could there be any link between the two?
Is it possible that engine light is just a routine emission control warning? There are lots of YouTube videos how to reset this light (not for VW)
Any advice would be appreciated.
Joe
There is a link.
After I added oil and checked the dip stick, I must have got distracted, and when I came back I closed the bonnet without closing the oil refill hole.
The cap did not get lost - I have driven only a few km like that.
However the warning light is still there, but I am pretty sure it just needs a reset.
error codes need to be cleared with VCDS
If I remember correctly there is a "register" that keeps track of the last 5 or 6 times the sensor registered an error. If you turn your vehicle off totally (key removed from ignition) and start it, then turn it off and remove key, then repeat a half dozen times the light should disappear from the dash if indeed the sensor is no longer registering a fault. If the light is still on once you've done that you really need to get a diagnostics run as Umai Naa!! said. In fact, it's probably worth doing anyway just to give yourself comfort there aren't any other looming problems that you can proactively address.
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
