Results 1 to 6 of 6
Thread: engine fault code 09571 boost control sensor
    Mar 2011
    sydney
    car : 09 tiguan tdi
    ive been getting the glow plug light coming on a few times and took it to the local mechanic.
    scan came up with 09571 boost control sensor.
    they said it was the turbo boost position sensor is faulty and it will be approx 900 bucks to replace include labour.
    does that sound correct? could it be something else? am i still able to drive it for a bit?
    this car has caused me so much grief...
    Jul 2015
    Sounds a bit expensive for a sensor... Have you tried getting another quote?
    Apr 2015
    Brsbane QLD Australia
    Is it a common rail tdi or the older PD tdi engine?
    DARKHORSE DEVELOPMENTS
    BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
    BRISBANE/GOLDCOAST/IPSWICH
    www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
    May 2006
    Adelaide South Australia
    It should be common rail.
    Numerous Mk1 Golf diesels
    Apr 2015
    If its common rail then the boost control sensor is part of the turbo wastegate. They loose vac pressure internally so they dont move. A lot if the cost involved is labour and basic settings adjustment of the wastegate after the install.
    Mar 2011
    sydney
    the mechanic told me that around half the cost is the sensor itself, the other half is the labour.
    he has told me hes done quite a few of these as it seems to be a common issue.
    does anyone know if this could possibly a solution? some repair kit?
    Turbocharger Boost Control Position Sensor - Skoda Octavia II (2004 - 2013) - BRISKODA.net
    maybe more info here
    http://ww2.justanswer.com/uploads/as...829_ANSWER.pdf
