Results 1 to 10 of 12
Thread: Emergency brake warning system
    Mackay QLD
    Has anybody activated this option in the #9 module using VCDS on their Tiguan? The brake lights are supposed to flash when brakes are pressed hastily. I tried pressing really hard and nothing happened. Must the car be actually moving to trigger the function if so by how much?
    Adelaide hills, SA
    Quote Originally Posted by Bambazonke View Post
    Most likely.
    Probably at least 30km/h
    Apr 2010
    Yes, only happens on an emergency stop. You can also set it so that you hazards flash in this instance, which is what various other new cars also do (you sometimes see it on car review shows like TopGear UK when they brake hard on a race track).
    Jan 2009
    If the vehicle is so equipped (or the function is enabled), when braking in an emergency, the brake lights will flash automatically above 60 km/h or when the ABS is activated for more than 1.5 seconds.
    When the speed falls below 10 km/h, the brake lights stop flashing and the hazard warning lights come on. They will switch off automatically once you drive off.
    The owner's manual is vastly underrated in this forum.
    Apr 2010
    They should provide two copies of the manual, one to keep in the car and one to keep next to your PC
    Mackay QLD
    Thanks for that Transporter & Ryan_R I will try it out on a quiet road tomorrow. Diesel_ vert this feature is not discussed in any of my 2008 Tiguan user manual modules. I came across this feature in the tweaks section of the Ross Tech's wiki link to the Tiguan during my research to enable my recently installed RVC to my rcd510. This feature was disabled in my car hence my query on the forum
    Jan 2009
    I find that hard to believe, but then again, I find that VW's owner's manuals are rather user unfriendly.
    Logically, one would've assumed that this safety feature would be standard across the range, from the Polo to the Phaeton, seeing how it's just a software mod, but I digress.
    Mackay QLD
    There are a number of options listed in the VCDS that are not even discussed in my users manual in addition to the above eg the option for your windows and sunroof if fitted, to be closed automatically using the rain sensor mounted on the windscreen should it rain. Suggest you do an auto scan of your modules and browse the long coding options that are available for standard but not activated
    Jan 2009
    Yes, although unlike the frivolous comfort and convenience features, I'd have thought such a helpful, if not fundamental, safety feature would be standard across the board.
    But it would appear that isn't the case. Oh well, looks like I was wrong. Nice one VW.
    Jul 2010
    Other VCDS coding for the Tig here:
    http://www.vwwatercooled.org.au/foru...ons-57346.html
    Feel free to share any others there.
    MY11 Tiguan 147TSI (SOLD)
