Results 1 to 10 of 12
Thread: DXD flywheel & Lighter flywheel discussion
    Quote Originally Posted by blutopless2 View Post
    something i have noticed with the manual 125 ... pretty much no engine braking... take your foot off the accelerator and the car will slow down quite slowly as compared to our previous polo gti, its almost like its in neutral.
    for my liking 1st gear is too short.
    I'm curious about the DXD flywheel that APR provide - the engine compression in a turbo-charged motor will definately be less than that of a naturally aspirated motor to compensate for the extra compression/boost that is created, but even still, the Tig's 'engine braking' is non-existant!! I wonder if it's a very heavy flywheel that's amplifying this, hence my interest in the DXD flywheel that APR provide...
    Might ask a few questions!
    Jul 2007
    Canberra
    I think you'll find the Tig TSI compression is the same as the NA 2.0, 10.5 IIRC? Be interested to hear what the engine breaking is like with an NA motor? Then again remember the Tig is quite heavy which would cancel out some of the effect, but you could be onto something with the flywheel, you need to buy one and tell us how it is
    Forever blowing bubbles.
    Adelaide hills, SA
    Quote Originally Posted by krracing View Post
    The lighter flywheel will improve engine braking, but you will have to rev the engine more, also you will have to be quick on changing the gears or you would stall the engine. Install too light flywheel and and you will hate driving that car in the traffic.
    I definitely recommend some reading on that topic, before you go ahead with the idea.
    Jul 2007
    Canberra
    Stall the engine with a lightened flywheel? Are you serious? If that were the case the engine wouldn't idle and I can tell you I've had 3 cars with lightened flywheels that have NEVER stalled. Don't mean to be confrontational but are you for real?
    Adelaide hills, SA
    Yes, I'm for real!
    When generally speaking about lightened flywheels.
    Unless you already have lightened flywheel in your Tiguan, you can't tell that it will not have any negative effects because every engine is different.
    Quote Originally Posted by Pullstarter View Post
    the engine would idle, but maybe not as smoothly, ...and you can stall the engine that doesn't idle properly when you change the gear or when taking off. I'm sure that many people experienced that the engine simply just cuts off when idle is erratic, either on take off or gear change. If it never happened to you; than you're a better driver.
    It also depends how much lighter lightened flywheel is, engine still could run reasonably well, but you may notice some changes. So, if you tell me that it never happened to you, all I can say to you is that maybe your engine had some other work done and the lighter flywheel was part of that modification, in other words the engine was blueprinted.
    How ever simple removal of flywheel on stock standard engine and replacing it with lightened flywheel (again it will depend how much weight was removed) may have some other effects.
    Hmm, maybe in original post I should use the words "could stall the engine" rather than "would stall the engine"
    Jul 2007
    Canberra
    None of the engines in which I had a lightened flywheel were blueprinted and I had no adverse reactions whatsoever. I've been around modified cars for the better part of 25 years, even full blown race cars with stupidly light flywheels made of rare and exotic alloys and I have never encountered or even heard of this problem. We will have to agree to disagree on this one.
    Nov 2007
    I can understand where you're coming from Transporter, but also agree with Pullstarter here ...
    In compression ignition engines (diesels in other word), the weight of the flywheel may certainly have an effect on engine idling.
    However (and I've also had a few cars with lightened flywheels) in modern spark ignition engines (petrols) the ECU controls the idling speed of the engine very effectively and automatically speeds it up as required and Ive never had an issue.
    Before and after flywheel changes no difference at all to the idling speed. The big effect of a lightened flywheel in any petrol car is that the revs climb much much quicker and drops of dramatically after easing off the throttle. It won't stall on the way down as the ECU prevents that. What you do lose is torque .... and the ability to sustain motion uphill .... unless you have a turbo ....
    I did have to adjust (very slightly ... 100-200rmin) the idling speed on a pre ECU 1800 16V Golf to compensate for the lightened flywheel, so this used to be somewhat of an issue, but in modern cars its no longer an issue ..... showing our age here Transporter ....
    Adelaide hills, SA
    Well, if that was that simple and without any ill effect on engine, don't you think that VW and other manufacturers would make lighter flywheels already? Instead, they go the other way - they make them heavier and dual mass.
    And I hear you already they make cars to suit even the worst driver.
    Nov 2007
    Its all about cost and the lowest common denominator..... lightweight flywheels are made of more exotic materials and are much more expensive to produce .... 3-4x the cost of a normal one ....
    And 99% of people will not appreciate the advantages you get out of a lightened flywheel.
    So in VWs eyes, why produce something that costs more and given the fact that very few customers are actually performance enthusiasts, very few will notice..... especially if it is available aftermarket ....
    Its all about the bottom line and not what is actually a better product ....
    Adelaide hills, SA
    Hmm, and I thought that flywheel is for balancing rotating masses, pistons, conrods etc.?
