Results 1 to 10 of 10
Thread: Does anyone know what is this?
    Aug 2011
    Westmead
    I currently bought a 2011 Tiguan. I found there is a small light just next to the main headlight.
    But I haven't seen it on even I tried the light switch in different position. Is this related to daytime headlight?
    Jun 2009
    The one on the right hand side is the regular beam light.
    The one on the left is the high beam light.
    The DRL's are apparently in the strip where the indicator i located at the bottom (from memory)
    Jan 2007
    South Australia
    I thought the DRL was through the parking lights? - like a Golf 6.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Jul 2010
    Are we actually talking about xenons or non-xenons?
    If it's the former, then the bulb that doesn't appear to light up is probably the static cornering lights.
    It only turns on when you're turning to light up the sides better.
    MY11 Tiguan 147TSI (SOLD)
    Aug 2011
    Westmead
    Quote Originally Posted by team_v View Post
    Thanks! I believed my Tiguan is non-Xenon. The strip light can only be ON manually but not auto, am I right?
    Jun 2009
    Quote Originally Posted by Explorer2 View Post
    To be honest i have no idea.
    Mine didn't come with DRL's so the strip light is only on when i turn on the lights to parkers.
    Aug 2011
    Westmead
    Thanks buddy! Maybe, my Tig has not got auto DRL becos I have to manual switch the strip light on.
    Explorer2
    2017 Tiguan 140 TDI Driver and Comfort package
    2016 AMG CLA 45 OrangeArt Edition
    2011 Tiguan 103 TDI; 2004 Subaru Forester Luxury Edition
    Sep 2011
    Perth
    if youre referring to what team V is pointing to (little strip below highbeam) yes its DRL
    DRL do not work on auto mode, you need to activate it by manually
    from memory mine works as follows (from left to right)
    off > auto > head lights > DRL
    Then when you pull the dial out when on headlights or DRL either by one or two notches you get your front or rear lights (if you have them)
    also apparently you can use VCDS to program your foggies to run as DRL too
    Aug 2011
    Westmead
    Yes, with refer to team_V photo provided, I can only manually switch that DRL either ON or OFF and the DRL is yellowish color and is not as bright as I expected. I just wonder has any people have it changed into LED strip.
    Explorer2
    Jul 2010
    Yes with an LED bulb!
    Only can achieve a whiter colour, but not increased output (brightness).
    Click on the DRLs link within my signature below.
