Results 1 to 3 of 3
Thread: Disable rear Wiper
    Feb 2013
    ACT
    Disable rear Wiper
    When we fit the clip-on bike carrier to the Tiguan the rear wiper operates and get stopped by the carrier sitting on the glass.
    It can't be too good for the motor to be powered up but unable to move.
    Not sure why the wiper operates, although the lever is easilly bumped.
    Is it possible to change the software to disable the circuit?
    Doesn't look that easy to pull the blade off the arm.
    Mar 2013
    Brisbane QLD
    The wiper operates when front wipers have been activated by rain and reverse is selected the wiper auto comes on...removal of the arm is just pull off the cap and undo the 13mm nut and wiggle arm off (can be very tight tho). Im sure with VCDS you can deactivate rear wiper or a least turn off the auto sweep in reverse.. VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2008
    Sydney/Canberra
    Might have to deactivate Tear Wipe as well.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
