Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: Difference between the 125 and 147 petrol models?
  1. #31
    Nov 2009
    Northern NSW
    and to follow up on clips post at the start of this thread......
    if doign the remap, its the Torque increase that you will really notice in everyday driving. The 147, picks up a wider band of peak torque, but peak torque figure is the same, and with that wider band comes the extra 22kw. But the APR upgrade adds about 45% extra to the torque peak and the increase over standard is quite noticeable from 1500rpm upwards.
    Tiguan TSI Catalina blue, Manual
  2. #32
    Albion QLD
    You people have failed to mention that the 147 isn't available in manual!
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
  3. #33
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by maca View Post
    But it has the 550Nm Audi 7sp DSG... why on earth would you want to spoil that kinda goodness with a manual?!
  4. #34
    Feb 2010
    melbourne
    Quote Originally Posted by Corey_R View Post
    So I will have no problems towing a van or boat?
    96 A4 1.8TQ
    K03-073, SUPERTECH VALVES, PORT N POLISH, JE PISTONS, SCAT RODS, FIDANZA FW & SOUTHBEND STG 3, BILSTEIN & H&R, 2.5IN EXHAUST, APR DV
  5. #35
    Feb 2009
    Sydney, Australia
    There is no difference in stated towing capacities between the manual and the DSG. 750kg unbraked, 2000kg braked.
  6. #36
    May 2009
    Is that 550Nm Audi 7sp DSG a wet plate or dry plate DSG?
  7. #37
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by triode12 View Post
    It features dual concentric wet multi-plate clutchs like the original 6sp DSG. The clutch design is upgraded and more complex though.
    So we've got the 250Nm 7sp dry clutch DSG (not the 7sp used in the Tiguan), which weighs 70kg and uses 1.7L of oil. The original 350Nm 6sp wet clutch DSG which weighs 93kg and uses 6.5L of oil. The 550Nm 7sp wet clutch DSG which weighs 142kg and uses 11.8L of oil (interestingly, two separate oil systems, one for clutches and mechatronics, the other for the gears and diffs).Clarifi
    Last edited by Corey_R; 02-02-2011 at 10:40 AM. Reason: Clarification based on below confusion
  8. #38
    May 2009
    So we've got the 250Nm 7sp dry clutch DSG, which weighs 70kg and uses 1.7L of oil. The original 350Nm 6sp wet clutch DSG which weighs 93kg and uses 6.5L of oil. The 550Nm 7sp wet clutch DSG which weighs 142kg and uses 11.8L of oil (interestingly, two separate oil systems, one for clutches and mechatronics, the other for the gears and diffs).
    Thanks Corey - very interesting.
  9. #39
    Jul 2010
    merewether, new south wales
    how does the 250NM DSG box cope with an APR upgrade
    if the new 7 spd dsg is 250NM how will it cope with the apr upgrade to 402NM? or wont it?
    2011 Tiguan 147TSi DSG, Silver Leaf, BiXenon, 18"s, ACC, leather, tow pack, bluetooth, now in the shed !!
    2007 Golf GTi Reflex Silver DSG, other worthy but aircooled German cars...
    http://www.autowerks.com.au/porsche_projects/index.html
  10. #40
    Nov 2007
    Quote Originally Posted by epilot View Post
    Corey_R was merely listing all the VW DSG gearboxes available .... 250NM DSG only in Polo's, Caddy's and Golfs.
    All Tiguans get the 550NM 7spd DSG box ....
