Results 11 to 20 of 24
Thread: Diesel Enhancements
    If you are interested, drop us a line, we can put you directly in touch with half a dozen Brisbane Diesel Tiguan owners that have the Oettinger treatment. Exact same car as yours & personal experience!
    info@hp.net.au
    Jul 2009
    Emerald , QLD
    BLUEfin & Tiguam TDI 103
    hi,
    I.m consider remap for my TDI am close to ordering a bluefin unit
    by Superchips
    www.mybluefin.com.au
    They offer both handheld device you attach to diag port which saves the original map and applies the upgraded one or a workshop remap like the oettinger
    claims similar results to Oettinger for about 1/3 the cost for the self applied remap. but i gather some later VW diesels have the ecu encrypted
    and need to be remapped in the workshop. at similar costs to Oettinger
    Any experiences or comments appreciated
    Ted Hagstrom
    2009 VW Caddy, Whte, TDi, DSG
    2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
    It's not only the later cars that need the new method, earlier versions of the EDC17 Ecu's are now being updated at VW service to the later encryption.
    So you may be able to program your car today with a cheap hand held unit, but after a service, you may not.
    On the power outputs, honestly, run a trial of each in your car - I'm pretty sure you will find a noticeable difference between the products. It's not all about the numbers.
    Link:
    Adelaide hills, SA
    There you go! Another great benefit from getting your car regularly updated for free, when you take it in for a genuine service.
    I think it's the time to put locking cover on the diagnostic port in our new Tiguan, should it accidentally be near to the VW dealer.
    Jul 2009
    Emerald , QLD
    Question for Guy &/or Jmac - if a workshop remap was applied. . and the vehicle had the VW ecu "upgrade" applied after,
    Does the remap have to be done again and at what cost
    Ted Hagstrom
    Dec 2008
    Alexandra, New Zealand
    Quote Originally Posted by Tedhaggie View Post
    As I understand it (I enquired with the NZ dealer) the Bluefin system will NOT work with the updated ecu AND they will not refund you should this occur after installation. That means (as I see it) that effectively your VW agent can (purposely or otherwise) completely negate the BlueFin with an upgrade to your ecu.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Adelaide hills, SA
    Quote Originally Posted by NZTiguan View Post
    As I understand it (I enquired with the NZ dealer) the Bluefin system will NOT work with the updated ecu AND they will not refund you should this occur after installation. That means (as I see it) that effectively your VW agent can (purposely or otherwise) completely negate the BlueFin with an upgrade to your ecu.Cheers
    If they don't ask you before they re-program the ECU. It brings up the question. Who owns your car? The dealer or VW? To be sure that your mods don't go away and your car is still running smooth with additional hardware that you fitted (if you did), tell them do not reprogram the ECU or anything in your car without contacting you first! The car was sold to you and complied to ADR at the time and is fit for the purpose. There is no need to tinker with it in the way they do.
    Do we have a lawyer here
    Jul 2009
    Emerald , QLD
    I understand the bluefin system will be useless if the VW upgrade applied and any previously applied updates reversed. , I suspect thatthe oettinger or.superchips remaps would also be wiped by th VW "upgrade" but that can be reappllied but who pays?
    Ted Hagstrom
    Nov 2007
    Not a practising 1 anyway ..... As I understand it (and I have not had time to read any doco on this) its pretty much the same as automatic updates from Microsoft for instance .... in order to remain complaint (and keep your warranty) all updates should be applied when they become available.
    Its a "service" offered by the manufacturers and not intended to cause harm, rather its intended to provide "fixes". Its the same as plugging in the diagnostic equipment and clearing any error codes.
    APR and Oettinger dealers will reload your ECU tuning software for only a labour cost (if any) For other tuners not widely represented in Aus/NZ you'r pretty much on your own....
    You are perfectly entitled to tell the VW dealer not too do anything like it, but this will
    1.) raise suspicion about your car being chipped with warranty implication issues, and
    2.) negate your warranty on any item/issue the "update" is meant to address.
    To keep your warranty healthy its best to do all your recalls & updates ....
    Alternatively, take your car to a VW specialist for servicing who will get to know your car and its "enhancements" and not do anything without asking you 1st ....
