Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Daytime running lights
  1. #21
    Sep 2011
    Townsville, Nth Qld
    Quote Originally Posted by aussietig View Post
    No ... they don't!
    Sounds like yours are fcuked already!
    The Tig is very sensitive and will pick up slightest problem if the error-free circuitry is not 100%.
    How long have you had them?
    Unfortunately the price we have to pay (perhaps every 6-9 months), if we want whiter lights!
    Certainly my previous ones (look at pics in post #14 above) were still physically working, but were throwing up an error.
    When I replaced them last night, the circuit board was pretty brown and fried.
    I think they're over 6 months old. Can't remember exactly.
    Hi mate,
    mine are about 3-4 months old, but been throwing error from the start (although not always). Must be borderline - close but no cigar (sigh)
    Have a few spares now anyway.
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  2. #22
    Sep 2011
    Townsville, Nth Qld
    I bought it from this seller and a current set listed: HB4 Error Free Load Resistors Bypass Wiring Decoder Set For Fog Lamp Lights #DC3 | eBay
    I very much doubt a stealer will do it for you!
    Firstly, they don't want to be held responsible or you coming back for any subsequent coding problems.
    But most importantly, I doubt if they would be able to work it out what to tick exactly.
    Not sure whether you'd want to be paying them by the hour to figure it out.
    Anyhow, suggest you print out the required tweaks and hand it to them as a cheat sheet.
    BTW, no point getting them to clear the fault codes until you have the wiring or error free bulbs sorted out.
    Otherwise will just come back straight after they clear it.
    Hi mate,
    just ordered a set of these resistors/plugs for my LED fogs - just wondering where you ended up attaching yours (the heat sink part with resistors in it)?
  3. #23
    Jul 2010
    Quote Originally Posted by Tiggy1 View Post
    Hi mate,
    Didn't bother. I just have it dangling.
    But made sure it didn't hit or touch anything.
    MY11 Tiguan 147TSI (SOLD)
  4. #24
    Sep 2011
    Townsville, Nth Qld
    Ok, thanks
    Hi,
    got these today and plugged them in to try - NO ERROR, Yippee!
    I think I will be pop-rivetting the resistor to the metal of the frame though - not too bad on RH side (plenty of room to leave hanging), but not so much on LH side, and many wires etc in close proximity. Things get freaking hot, so don't want to take the risk of melting through the insulation on other wires and whole thing going up in smoke (would ruin my whole day)
  5. #25
    Perth, WA
    For those interested, finally found a solution on eBay for the bulb out warning on my LED fogs.
    Here's the LED bulb that I've got on the fogs:
    Now here's the new lead that's gotten rid of the problem:
    So far so good!
    Hey aussietig,
    Do you have your foglights activated in VCDS as cornering lights? I ask as I want to know if the LED's flicker when they are fading off? If they do, I'll probably just stick with the halogens.
    Thanks for your help!
    Cheers,
    MCL
    MY11 Tiguan, 147TSI, Pepper Grey, DSG, Panoramic Sunroof, RVC, Bluetooth, MDI...
  6. #26
    Jul 2010
    Yes I have them enabled as such.
    No ... flickering was probably first generation thing.
    Current LEDs even handle dimming.
    But obviously it depends on the quality of your LED bulbs.
    If you can't tell then price & location sold is quite often a good indicator.
  7. #27
    Perth, WA
    Excellent, will get some from the same seller you got yours from!
    Cheers!
  8. #28
    Sep 2011
    Townsville, Nth Qld
    Hi.
    have riveted resistors to couple of handy spots near fogs - pity the leads aren't a bit longer, as I had to turn my RH foglight upside down so I could get it to reach! Got them reprogrammed as DRL's when I had flappy paddle steering wheel fitted and all working good. My LED park lights still throw an error occasionally, but if I flick the light switch from Auto to Parkers on and back it clears the error (until I shut the car down again). Must be borderline as I said in earlier post. Anyways, no biggie and might look at trying some others down the track
  9. #29
    Jul 2010
    Well you might have a better chance getting new LED park bulbs approved as early x'mas present.
  10. #30
    Sep 2011
    Townsville, Nth Qld
    Way ahead of you - have another set on the way already from MyLitCo
