Originally Posted by
airofu
Just wondering if anyone has installed a Blackvue dashcam with Blackvue Power Magic Pro box on a Tiguan 2014 or similar year, and if you have the location and fuse connections to use for constant and switched power? I've read some VWs and other euros have issues with the battery giving too low a voltage for the constant connection to use when the engine is off?
Fuses probably behind Glovebox as in the MK 2 Do you know how to use a multimeter????? Easy to find which are which. A PMP can be set from 12v UP Havent had any trouble in my VW 's until battery got old.
It might help , not sure but the 2017-20 fuses are top row always on 3rd row ACC Look in the manual as it has a listing of what is on which fuse Make sure you use these to connect and around the correct way.
