Results 1 to 10 of 18
Thread: Cruise Control
    Cruise Control
    Hi Everyone,
    One thing I noticed with my Diesel Tig is that when I enable cruise control and the car comes to down hill the speed is not maintained and it goes over the speed. Has anyone else noticed this.
    Thanks.
    Jul 2009
    Middle Ridge QLD
    Varsur, We have had our Tig for just over a month and I have noticed the same thing. Have not consulted dealer yet.
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Yeah, mine's the same. The Cruise control basically seems to control the accelerator on, so on a downhill where the engines compression braking isn't sufficient to retard the vehicle, it will go over the speed set. Was the same in my Petrol Bora to be honest.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Jul 2009
    Quote Originally Posted by TigWhite View Post
    I believe this is normal for all cruise control systems. I think there is an "adaptive" one in the other models of VW.
    DieselTig
    Tiguan Tdi Auto
    Jan 2008
    That's normal operation for most cars with cruise control. Drop back a gear or two. "Problem" solved. You could also RTFM as this is covered in there under "cruise control"
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Quote Originally Posted by DieselTig View Post
    Adaptive Cruise Control (ACC) that is available on the Passat and new Toureg won't solve this problem either. The ACC has a radar behind the badge on the grill that detects if you are within a set distance (or number of seconds) of an object in front of you (presumably another vehicle) and adjusts the speed of the cruise control to maintain that distance.
    Nov 2008
    QLD
    Mine is very precise and holds it extremely well, as good or better than anything I've ever had and holds the the speed up hill and down. Only thing I noticed is it accelerates a little when first setting the speed, then settles to where I set it. All other vehicles I've had do the reverse - the car slows a tad and then speeds up to the set limit.
    Mar 2009
    Its easy to set the Cruise, but it takes quite some getting used to to find and flip that little switch sideways to turn it off.
    You can tell by its "poor orphan cousin" location that cruise is pretty much an afterthought for the German market.
    TDI tiguan in the drive. ParkAssist, comfort, fogs
    Service every 15,000, new fault code every 7,500km
    Dec 2008
    Sydney/Canberra
    The VW system is one of the better ones out there.
    You could do worse, ie automatic current model Suzuki Swift.
    Nov 2007
    Cruise control buttons .... ??? they work just fine setting the APR maps thankyou ....
    Seriously though, I've always found the cruise control on a VW to be quite good, better than that of a Toyota for instance. If you want adaptive cruise with slow down etc funcions, spend $50K more and buy a BMW, M-Benz or Audi.
    Again it comes down to ... "you get what you pay for"
