Aleft feid comment
THe general info on a 215/65R16 trye has the following
Calc radius 344mm
Static radius 313 mm
Dynamic Radius 333 mm
THe info on the Bridgestone HP gives a calc of 343
The CS4 344
I suspect the the CS4 is a much stiffer tyre and and the dynamic radius Could be 6-8% higher.
THis affects fuel consumption in 2 ways
1 your actually going 6% faster = more fuel probably of the order of 10%
2. your actually going 6% further -
So apparent impact on Consumption would be 16.6%
ie 6% + 10% + (10% X6%)
if you have GPS a speed comparison with the digital speedo might answer my question
Ted Hagstrom
2009 VW Caddy, Whte, TDi, DSG
2009 Tiguan, silverleaf, 103Tdi ,auto, Comfort pack, leather, fogs, Rns510 with RVC
