Other than from the dealer would be from your dealer.![]()
Reason for that is, because it's cheap. It's 1.5L not 1L and it is a concentrate, it will make 3L when diluted 50:50 and use only distilled or demineralized water (very important). For once only top up when you need only small amount (200ml), use distilled water. But next top up if needed should be concentrate or correct mixture.
