Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 71
Thread: Coil Pack Issues with in Tune Mode?
  1. #51
    Dec 2009
    Canberra
    Apart from the red colour which is good for 5kW itself, the stronger spark won't really have a noticeable effect on engine output.
    Yeah wasn't expecting more power, just wanted to fix the dead spot when revving that was iddentified as a coil issue after getting the stage 1 tune.
  2. #52
    Quote Originally Posted by 08elf View Post
    No problems. Glad you got it sorted
    Jan 2012
    Sydney, Australia
    I replaced the revision A (06H 905 115 A) coil packs as a preventive measure, and immediately the car picks up rev much quicker, specially off idle.
    Which means I have been driving around with a dying coil pack(s) for the last 20000km without realising it......
    MY12 Tiguan 132TSI + DSG
  4. #54
    Quote Originally Posted by z1000 View Post
    Not sure if your coil packs were dying but the R8 ones do give a stronger spark which can help with combustion.
  5. #55
    Jan 2012
    Sydney, Australia
    Does stronger spark mean spark plugs wear out sooner?
  6. #56
    I don't believe so. Just means you get a bigger spark each time and tends to ignite the fuel better.
    Where you run into problems is when the coil pack doesn't create a large enough voltage to jump across the gap and then obviously you don't get a spark/ignition.
    You still have to have the right fuel/air mix so if you run too lean you'll end up with a hotter flame (and possible singe things). If you're too rich you'll get a sooty build-up.
    May 2013
    Took my Tig in to VW to check out an ECP fault and was told that it was a coil pack failure. They didn't have any in stock and needed to order one in. Tig just turned two years old the other week and had 60,000 KMs. No tune or performance mods done yet, was holding out for a sale with APR.
  8. #58
    Quote Originally Posted by scooby View Post
    Hopefully they replace the complete set. Ideally all coil packs should be "matched" - same with spark plugs.
    When I had one go they only replaced the single coil pack because my car was "tuned" (they usually will replace the set).
    I actually don't understand this logic. Either the tune caused the problem and it's not covered or it didn't cause the problem and they should replace the set.
    Anyway they ended up replacing a series "A" coil pack with a series "B" and left the other 3 as series "A".
    I took the opportunity to replace the lot with the R8 coil packs as I didn't trust the others. I now carry them as spares - just in case.
    May 2013
    Got the car back today and the dealer only swapped out the faulty ignition coil. Oh well. I'll probably to do the same and get some spares in the trunk.
  10. #60
    May 2013
    Well, it didn't take long. Cylinder 3 started misfiring on the drive home today (previously it was cylinder 4 with the faulty ignition coil). Will have to contact the dealer again to book the car in.
    So now I'm thinking of holding off on getting the APR tune in case there is an underlying engine issue.
