Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: Coil Pack Issues with in Tune Mode?
  1. #21
    Feb 2013
    Bathurst NSW
    Just did a coil pack today, cylinder 3. 2011 tiguan 147tsi with APR Stage 1, 50,000 k's, first problem since new 2 years old today.
  2. #22
    Sounds like it's coil pack month for the Tigs. Had one go this morning 2011 125TSI done 42,000km/2 years with Viezu performance stage 2.
    Sep 2011
    Townsville, Nth Qld
    Re: Coil Pack Issues with in Tune Mode?
    Yoiks - might be time for a group buy on coilpacks fellas?!
    Seems strange for these failures to all happen at once though. Hmmm, wonder if the fuel companies are watering the stuff down even more
    Sent from my PadFone 2 using Tapatalk 2
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
  4. #24
    Quote Originally Posted by Tiggy1 View Post
    Been thinking that myself and done a bit of investigation. A lot of the GTI boys are putting the red audi R8 coilpacks in and changing spark plugs. Apparently it's a fairly common issue when you go past stage 1 tune that the stock coil-pack just give up.
    Anyone up for a set of red R8 coilpacks?
    Sep 2011
    Townsville, Nth Qld
    Yeah - red ones better (go faster)
    Seriously though, good plan Tigger73 - obviously would be more performance oriented than our stock ones. What sparkplugs do they recommend changing to?
  6. #26
    There's a few different types of spark plugs. ECS tuning sell sets with coil packs and spark plugs: Volkswagen Golf VI 2.0T > Engine > Ignition
    Anyone interested in a set. I know I am.
    Sep 2011
    Townsville, Nth Qld
    The one with red coilpacks and bosch plugs? I'm in - hopefully won't need them (until I get tune sorted anyway), but cheap insurance I reckon
  8. #28
    OK I'm going to order some new coil packs (series "E" red ones) just to be on the safe side as a few of the tuned Tigs seem to be having some failures and the poor old Tig doesn't go so well running on 3 cylinders. A lot of the tuned Golfs use these due to the (relative) high failure rate of the "stock" coil packs. Consider it cheap insurance to stay on the road plus the red coil packs look pretty cool.
    Cost will be $125 pick-up/drop-off in Adelaide or add $15 for shipping Australia-wide.
    There's a few other options available (Volkswagen Golf VI 2.0T > Engine > Ignition), though the spark plugs can be probably purchased locally for less (once you factor in the freight costs).
    I'm going to place an order with ECS tuning on Monday so PM me by the end of the weekend if you want a set.
    Jan 2011
    Brisbane - QLD
    both my mk6 gti and tiguan have this part # 06H905115, instead of the red coloured one's.
    Home Page > Search > 06H905115 > ES#2216599 IGNIT.COIL - 06H905115B
    would the red one be compatible?
    MINI Cooper S Clubman - FWD
  10. #30
    Quote Originally Posted by nat225 View Post
    The red ones are stock units from a lot of higher end audis (including R8 ). They are compatible as ECS are selling them as suitable for GTI and Tig and a lot of people have put them into these vehicles without an issue. If you're just running stock tune then the standard plugs and coil packs are fine, however if you're running a tune (and more so with hardware mods), the standard items can become a weak link.
    Hence after one failure I'm replacing the lot. I'll keep the stock ones as spares and leave one in the boot should I get stuck again.
