Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Changing gears - does anyone pay any attention to the MFD?
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by tigger View Post
    Hey guys...
    I might be a bit stupid, but my 2010 125tsi tig (manual) does not show the gear chosen on the MFD.
    My 2010 125TSI Manual doesn't either.
    Feb 2010
    Camden NSW
    Well, I coincidently had a service done today and asked Barloworld about it. They said that it depends on the Chasis number as to whether this feature is available or not.
    It seems that not all have this feature. They did say that they would keep checking with the service computer systems that VW have worldwide and see if and when an update is provided.
    Strange that this would not be standard when a base model polo has it??...
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Apr 2009
    I drive an auto. It shows the gear that is is in, at any given time. Ok, it is not exactly a must-have, but is entertaining to see when it is kicking-down, or just to get a feel for the gearing.
    Such is the torque (280nm), that the car is often in a higher gear than you would expect, and I'm sure this is particularly so in the Diesel (320nm)
    By the way, how smooth is the Auto in the Tiguan? I think it is like a CVT without the noise and lag. Ripper drivetrain, Petrol or Diesel!
    _______________
    125 TSI Auto, SunRoof, Park Assist, Lux Pack
    Sep 2009
    Harbord, NSW
    It does say in the manual that you can ask to have the function turned off by the dealer, so I'd presume you can have the function turned on. But I wouldn't bother.
    2010 103TDI MANual, offroad kit, nuffin else
    i am not sure if this helps but for those of you who know me (i dont normally post in this section) will know i work for Ford.
    This is my thoughts of why it is telling you to run a higher gear than you think as we do the same here in ford.
    One of our new engines runs off boost, it is to keep the emissions down. (below 1500 rpm) Yes it seems the engine is struggling but it is the best for emissions. (so i have been told)
    I question this on a recent drive event but i was told that this is the best way to help the engine and transmission meet their targets. (i was driving an auto at the time)
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Jun 2009
    Quote Originally Posted by velly_16v_cab View Post
    I agree that it is probably set to show the best emissions/economy.
    It was saying i should be in 6th at 60km/h today...........
    Generally it tells you to change up if you sit on anything over 2,000RPM but it isn't worth changing up imo until you are at 3,000 otherwise it really sounds like it struggles.
    Nov 2008
    QLD
    It's all a load of bollocks IMHO, and is purely for what Velly says - all about emissions. I'd be getting my dealer to turn it off.
    Mar 2010
    Prahran, Victoria
    The gear selection system seems fine. I have the 103TDI manual so my experiences are based on this...
    The gear selection seems to want to keep you at around 1250rpm. Below this point, the engine will start to struggle. At 1000rpm the engine is struggling. I haven't tried it, but it'll probably stall at around 700rpm.
    The gear selection system does not know the driving conditions you are in or the terrain you are approaching, therefore it can only make its recommendations based on current gear, rpm and throttle position.
    If i'm doing a constant 80kph in 5th on a flat road, it will ask me to change to 6th. However, if I put my foot down or get to a hill it no longer wants me to change up.
    No reason to sit at 2000+ rpm if you're cruising on the open road.. seems to be working as intended!
    Nov 2009
    Northern NSW
    Quote Originally Posted by team_v View Post
    really? Team V with the 190 TSI there is just tons of torque at 2000rpm (about 350nm). Sure if you change up then the engine will drop back to about 1500rpm, and if you floor it it wont respond that well and may sound like struggling. But even at 1500rpm I have found the response quite adequate without any sign of struggle as long as I dont expect major acceleration. So depends on how much throttle.
    Of course at 2500 upwards thats where things really start to boogie, but there is so much torque below that, you dont need to go above 2000-2500 unless you want things to happen very quickly
    I have just let the car idle in 4th and it gets along fine and then even accelerated from idle in 4th! up to speed and even that extreme is OK (ie no obvious engine complaint) as long as throttle use matches likely throttle response at those revs. All Tigs will be roughly the same, just the throttle response a bit different. Its just that the 190 TSI is especially strong right from idle.
    Tiguan TSI Catalina blue, Manual
    Jun 2009
    Quote Originally Posted by jimbomort View Post
    it might have been mine still running in as it seems a bit better now.
    It is happy to cruise along at 1500RPm and will comfortably do 60km in 5th gear.
    I still find it isn't worth changing gears until you get to 2000RPM as the revs will drop to 1500 if you do it then and you can still drive without it sounding like it's struggling.
