Hi There,
I have done it - not too hard. Took about an hour to both sides.
Make sure you put the battery charger on to keep the voltage up.
Wayne
Just wanted to get some advise on changing brake pads. I already looked at YouTube video on how to change rear brakes via ross tech cable and was wondering if it was difficult. Anything to look out for?
Anyone done it themselves? Length of time to get it done?
Regards
http://www.youtube.com/watch?v=cHJMI4QkSy8
Hi There,
Wayne
Thanks Wayne, did you change your rotors as well and restore brake fluid?
Make sure you run the test mode after installing the new pads, this resets the gap between rotor and pad.
No just the pads - fluid was done at previous service. Didn't do the rotors - they were not worn at all.
