Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 61
Thread: Ceres_mining_co’s Tiguan build
  1. #51
    Yeah first look at the DP/heatshield to see if there’s any contact/rubbing.
    DSG tune should increase clamp rates for the higher torque you’re putting through now.
    Aug 2017
    Sydney NSW
    Ok cool I might have to keep an eye on it in the meantime, it's so odd that it doesn't happen in higher gears...
    MY11 Tiguan 125TSI | 4Motion | DSG | APR Stage 2 | GolfR IC | HF turbo outlet + throttle pipes | CAI | 3" DP
    Ceres_mining_co's Tiguan build
  3. #53
    Quote Originally Posted by Ceres_mining_co View Post
    First gear can be a bit clunky on downshift as the synchros engage.
    Aug 2017
    Sydney NSW
    After everything the Tig has been through, I think it's fair to say she has earned her "R" badges!
    The rear end looks a lot cleaner now I reckon
  5. #55
    Hey mate, looks good without the badges. Did you notice an increase in noise/drone from the cts downpipe or does it sound 'stock'?
  6. #56
    Aug 2017
    Sydney NSW
    Quote Originally Posted by LMAA View Post
    Thanks mate, I was debating leaving the TSI badge on the right hand side but I'm glad I took it all off.
    Definitely noticeable, but personally I don't find it too intrusive. It comes alive inside the cabin when driving hard but when you're potting around you just get a subtle drone.
  7. #57
    Sep 2017
    There really isn't too much you can do with exhausts on our engines. I get a drone on stock exhaust around 1100-1300rpm. Really noticeable when I'm in 6th gear at 60KMH in D.
    Did you sort out that thumping noise you were getting?
  8. #58
    Aug 2017
    Sydney NSW
    Quote Originally Posted by DannyBoy View Post
    I don't mind the noise tbh but I will always be a boy racer deep down hahaha!
    I've noticed the thumping comes back after driving the car on the freeway (for at least 30 mins) or after driving it hard. If I drive it like a normal person it's pretty much non existent.
    That vibration keeps coming back though, I'm convinced something is rubbing up against the heat shield...
    Sent from my SM-G930F using Tapatalk
  9. #59
    Feb 2015
    Sydney, Australia
    Hey Ceres,
    With your discharge pipe photo, could you possibly be missing a hose clamp at the rubber hose connection there??
    2015 MY15 Tiguan 155TSI R-Line ~ Pan roof /Bi Xenon's AFS /RNS510 /RVC Plus /DSG7 /APR Carbonio Stage II intake kit, IC, Oil CC, Boost tap /Neuspeed charge & discharge pipes /Neuspeed & ECS end links/ VWR BBK & SS lines/ H&R sway bars /APR ECU Upgrade /HP DSG DQ500 Tune/R8 Coil Packs/GFB DV+ /ABT kit! (FAMILY CAR)
    2014 F30 328I (ME CAR)
    2011 E46 330CI (SOLD)
  10. #60
    Aug 2017
    Sydney NSW
    Quote Originally Posted by Evilz View Post
    Hey Ceres,
    Hahaha well spotted! I found out the hard way when I took her for a drive shortly after taking that photo, had a lovely squealing noise on boost and had to get under the car again. What a muppet.
