Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
Thread: Ceres_mining_co’s Tiguan build
  1. #31
    Nice work.
    Probably the only thing left before going to a K04 is to get a DSG tune.
    There's torque limiters in the DSG software that put a cap on what gets let through the transmission. So even if you make the power in the engine, unless you take the limiters off in the transmision, you won't see it at the wheels.
    It's not going to be a massive jump in performance but when you get to where you're at it's all about incremental improvements.
    Plus it drives a lot nicer and will drop back to 1st gear when you need it.
    Aug 2017
    Sydney NSW
    Nice work.
    That's a really good shout you know. I've hated the shifting patterns of my DSG since I've owned the car, I feel it's a real weak link. D and S modes never seem to find that sweet spot so I'm hoping the DSG tune can solve for some of that. I don't have steering wheel shifting paddles so using manual mode is a bit of a hassle.
    Mind you at about $1,200 that's a hefty investment, will have to wait until next year.
    MY11 Tiguan 125TSI | 4Motion | DSG | APR Stage 2 | GolfR IC | HF turbo outlet + throttle pipes | CAI | 3" DP
    Ceres_mining_co's Tiguan build
  3. #33
    Depends what sort of driving you do but I'd also seriously consider steering wheel swap/DSG paddle shifters and a rear sway bar if you're going to go hitting some twisty roads. Much more fun in manual mode with paddle shifters in the twisties and the rear sway bar will sort most of the body roll issues.
    There you go I just added another $1k to the shopping list
    Aug 2017
    Sydney NSW
    This isn't helping, that is EXACTLY what I want to do after the DSG tune!
  5. #35
    Quote Originally Posted by Ceres_mining_co View Post
    Sep 2012
    You may have to introduce a rule - anyone suggesting a mod must contribute 50%
    Indium Grey Golf 7.5 Alltrack 135tdi Premium - all options
  7. #37
    Aug 2017
    Sydney NSW
    Quote Originally Posted by Rooboy View Post
    50% I'm ok with that! Maybe I can backdate it to the start of this thread hahaha
    Sent from my SM-G930F using Tapatalk
  8. #38
    Aug 2017
    Sydney NSW
    Quote Originally Posted by DannyBoy View Post
    Stock tune didn't make any difference. Stage 1 running 20psi, basically going from 2k - 3k revs and closing the throttle makes a consistent woosh noise. This is with a GFB DV+ which doesn't completely replace the DV, just the diaphragm section which is likely to break if you're running a revision lower than "D". It also comes with 2 springs, which I'm running both.
    GFB Blow Off Valve BOV DV+ T9351 fits AUDI A5 8F7,8T3,8TA 2007-2016 | eBay
    It made a difference in throttle response + helps hold boost between gear shifts. Probably less likely to notice a boost drop between shifts on a DSG.
    I'm running everything stock, except the DV and a Stage 1. So I'm assuming that it'll be louder when letting off throttle after boosting on your car.
    Has the car had it's coil packs replaced? A good tip is, if they go; a lot of people recommend replacing them with R8 coil packs (red cap).
    Hey mate did you install this yourself? Is your tig 4motion?
  9. #39
    I might have to keep my mouth shut... it could become expensive quickly.
    Aug 2017
    Sydney NSW
    I think we'd all be stuffed
