Hi, haven't had whistling noise (have Carbonio as well), and I can't imagine it would be DV as the newer piston type are much better than older diaphragm type. I would be very carefully checking ALL hose connections to make sure there is no chance there is any way air could be leaking through. I probably went overkill, but have two constant torque clamps ( ones with spring and nyloc nut so they can't vibrate loose) on my hose connection from CAI to OE pipe!
On the topic of noise though, since having tune done I have a weird "chuntering" noise at low to medium revs/throttle - sometimes combined with slight hesitation. It is very mechanical noise which suggests it is coming from exhaust side of turbo?!
Has anyone else experienced this? The tuner believes it may be related to CAI, but I would have thought their tune would have made allowances for change in MAF readings...
Very puzzling
Sent from my PadFone 2 using Tapatalk 2
2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
