Results 1 to 10 of 12
Thread: Car performance measuring devices
    Jun 2013
    This is not directly relevant to Tiguans, but I know some members are using these performance monitoring boxes..
    Can someone comment on accuracy and recommend relatively low cost device to measure acceleration of cars.
    I am looking at Vbox(expensive) and Gtech pro.. Can some one comment on those.. Thanks
    Jan 2011
    Brisbane - QLD
    1/4 mile strip would be cheaper, accurate and legal
    Or dyno runs if u prefer raw data.
    Jun 2009
    I believe the Polar FIS allows 0-100 and a range of other options integrated into the MFD.
    Jan 2011
    Brisbane - QLD
    the cheapest would be a Torque Pro App (on an android phone, us$5) and a bluetooth dongle (around us$15 eBay delivered). the accuracy is probably not the best though..
    MINI Cooper S Clubman - FWD
    Jun 2009
    Quote Originally Posted by nat225 View Post
    That is the biggest issue i believe.
    You have to get a strong GPS signal with a quick refresh rate (I have heard 5Hz bantered around) in order to get an accurate reading.
    I don't know if the gps antenna with the RNS510 is even that good.
    Jun 2013
    Quote Originally Posted by team_v View Post
    Yes ... I used that setup ( Torque pro/ dongle) and it sometimes give very confusing results.. Torque pro uses OBD2 signals from car ecu for 0 ~ 100 timing I believe but not sure...Also it does not give any result for some runs.
    Gtech pro is relatively cheap not sure about the accuracy though..
    Jun 2013
    Feb 2008
    ACT
    I've found the RaceLogic Performance Box / Video Box / VBox products to be suitably accurate tools, though they're not cheap ($500+).
    I use mine primarily for racetrack lap times where the GPS lap time is usually within 1/10th of the Natsoft recorded, transponder-based time. Not F1 accuracy but more than sufficient for my needs.
    For straight line acceleration runs I've found them to be pretty accurate also - again within a few tenths of the laser recorded times over various 800m and 1000m standing sprint events.
    The older Performance Box I've got is a 10Hz unit - i.e. it gets an updated GPS fix every 1/10th of a second, and uses fancy maths to calculate splits between those fixes. Their newer models now support 20Hz (i.e. 1/20th of a second) updates.
    Quote Originally Posted by jamesatfish View Post
    James,
    How do you find these compare to the AutoPolar? Have you run any comparisons using the AutoPolar FIS+ for 0-100?
    Be interested in any "real world" results.
    I've found my 0-100 times are quite repeatable using the Autopolar but not sure how accurate they are.
    Feb 2008
    ACT
    James,
    I actually haven't thought to compare the AutoPolar and the Performance Box - will grab the PB out of the Polo sometime this week and give it a try.
