I do recall seeing the somewhere so I think the answer could be yes.
I'll research but expect some of the VW Geeks to come up with the laser sooner.
Dinah
Currently flashes 3 times, I'd like 4. Can this be coded?
09 Polo GTi "Elke" | APR DV1 | H&R 35mm | Bilstein B8 | Remsa Pads | Pioneer |
Dinah
From Ross Tech wiki
VW Golf/Jetta/Bora (1K/5M) Tweaks - Ross-Tech Wiki
Comfort Turn signals may be turned On -or- Off via coding. The number of flashes cannot be adjusted.
I assume this applied to Tiguan as well.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Can be in a B7 Passat as mine were 3 and I reset them to 5 Gets done in VCDS Cant remember which module though
So, VCDS Tweak
VCDS > Select > 09 - Central Electronics > Adaptation - 10 > Channel 31
TIGR
2017 162TSI R-Line Tiguan - Tungsten Silver | DAP | APR Stage 1 Build thread: https://goo.gl/YNgixR
2015 155TSI R-Line Tiguan - Build thread: https://goo.gl/sEqISR
Thanks TIGR5 sounds even better
