Page 9 of 14 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 131
Thread: CAM chain tensioners failing..... TSI engines.
  1. #81
    Nov 2009
    Illawarra NSW
    It is a genuine part, but the updated version. Not only a ratchet to hold tension on the chain when there is no hydraulic pressure, but also a spring. Virtually failsafe, hopefully. There has been about 4 reincarnations of the tensioner and this is the latest.
    Here is a link to everything you need to know;
    http://www.golfmk6.com/forums/showthread.php?t=55992
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
  2. #82
    Arrawarra
    New Motor Going Strong!
    Well, 12 months has passed since starting this thread & 20000km's clocked up & the new motor is faultless. Might have used a little oil in the 1st 5000km, maybe half a litre, but i changed that oil then (early) & it's hardly used any over the next 15000.
    A couple of small issues were quickly rectified immediately after the new engine went in - they were a heat shield rubbing on the driveshaft to the rear wheels that would make a scraping sound occasionally, & some sort of pinched O ring where the turbo bolted on, making the odd hissing sound.
    All good, still a happy VWer!
  3. #83
    Adelaide hills, SA
    That's a good result, ...and no excessive oil consumption.
  4. #84
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by MGV View Post
    Good to hear!
    An engine change is a fairly big undertaking, so there's always the odd teething problem that will spring up. Unfortunately some require some miles before they do. Fortunately in your case, you had a cooperative and sympathetic dealer to sort it out
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  5. #85
    Sep 2010
    Brisbane, Queensland
    Just adding my 2 cents.
    I bought a Golf GTI MK6 second hand last year and it started the rattle earlier this year.
    It is 6 months out of warranty, but I called VW Australia and they said I can take it in for good will assessment at my local dealer. I was willing to pay the diagnosis fee, but based on the service managers feedback he said it would be most likely be covered as the tensioner is known TPI.
    So after having it for the day they rang me and said all covered by warranty, just have to wait 2 days for the parts. Car went in, and during that time they also found another tensioner that was not serious, but worth replacing while the engine was open, so they rang and informed me that they would get this part as well and car will be done a day later.
    Picked up the car and been perfect since, no rattle and all paid for by VW. Happy customer.
    They also been trying to fix the hesitation on my Tiguan, but I think after replacing the coils and PCV with no change, it is leaning towards what people have mentioned on this forum. Dreaded carbon build-up. Will see what they can do about this in the coming weeks as it seems a little better for some reason.
    Ps. They also replaced the battery in my Tiguan this week under warranty (battery was 3 years old).
    Overall been very happy with dealers help with both my cars.
  6. #86
    Jan 2011
    Brisbane - QLD
    Tell us which dealer has done that excellent customer care?
    Sent from my GT-I9300T using Tapatalk
    MINI Cooper S Clubman - FWD
  7. #87
    Sep 2010
    Norris at Kedron - forgot to mention that
  8. #88
    Oct 2010
    Again! Thought I had it fixed late last year, it's back! Rattling is back from the dead. Got under the car and checked wastegate clip, was solid as a rock. Maybe not fitted correctly and stretched. Please not the tensioner. Booked in early next month. Might as well ride a bicycle, reliable.
  9. #89
    Ive just realised that my newly purchased (2nd hand) 2010 Golf GTI is making this rattle on startup. Every time i have started the car over the past few weeks and heard this noise, i have wondered if it was the timing tensioner.
    Looks like ill be buying a tensioner kit from USA and replacing it. That will be fun
  10. #90
    Sep 2010
    Lucas_R - you could go to VW and mention that it is a common problem. My car is second hand 6 months out of warranty and they replaced all the tensioners in my car under good will warranty. Didn't cost me a thing.
