Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 131
Thread: CAM chain tensioners failing..... TSI engines.
  1. #71
    Nov 2009
    Illawarra NSW
    My TSI has never been serviced by a dealer and has a "Superchips" tune from new. It recently started the dreaded start up rattle. Rather than wait for the inevitable I bought this and found a good mechanic to fit it. It is worth the peace of mind.
    HS Tuning - TSI Timing Chain Tensioner Update Kit - 06K109467K
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
  2. #72
    Oct 2013
    Central Coast, NSW
    It says it's an OEM part, does that mean it's the same part they use when they have been replacing the faulty tensioner?
    Sent from my SM-N9005 using Tapatalk
    MK6 Golf 90TSI
    Silver
    Manual
  3. #73
    Adelaide hills, SA
    Quote Originally Posted by ryno_07 View Post
    It refers to the OEM number and the description says "it is a new style tensioner".
    They have to use the OEM as a reference otherwise you wouldn't know what to get.
  4. #74
    Oct 2013
    Central Coast, NSW
    Do you know if this would be better than the new one VW is using?
    Thanks.
    MK6 Golf 90TSI
    Silver
    Manual
  5. #75
    Adelaide hills, SA
    I didn't use it, so I don't have the first hand experience with it. I would expect it to be better and to resolve the issue, if the fault was caused by only a tensioner.
  6. #76
    Oct 2013
    Central Coast, NSW
    Well, considering mine has been replaced with the "updated" model from VW i'll see how it goes and if i get the problem again i will consider this alternative. Thanks for making me aware of it.
    MK6 Golf 90TSI
    Silver
    Manual
  7. #77
    Adelaide hills, SA
    The VW updated part should be as good as or better than an aftermarket updated part. Time will tell.
  8. #78
    We have built a few of these engines recently - just use the new factory updated version & you will be fine. We rev ours to over 7300 all the time under high load.
    I'll see if I can get you a picture of the early & late versions.
  9. #79
    Adelaide hills, SA
    Great info as always.
  10. #80
    Old style tensioner
    New Style
    Might as well put some nice stuff in there whilst you are going
    Then go out & test it.
    P.S. - this engine is now in our Tiguan
