Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 131
Thread: CAM chain tensioners failing..... TSI engines.
    At least everybody with the rattle noise from the engine at the start up, should go to the dealer and get it looked at. If they say there was nothing wrong, get it in writing and make sure that they mention that you're concern about the possible timing chain tensioner failing and destroying the engine. Then if something happen and the car is out of warranty, you're on the top.
    That's what I would do.
    +1 if you have a 2010 model just about to run out of warranty I'd be onto it pretty quick.
    I wonder what the cost of replacing the tensioner is?
    For those out of warranty it may be a worthwhile investment/insurance policy just to get this changed before a catastrophic failure. Even though VW should probably foot the bill it's likely they won't do a recall now (even though it is a know issue due to change of component).
    hmmmm
    what impact does this have on your resale given the new engine has a different number to the original compliance plate?
    Feb 2013
    Perth, WA
    Providing it's done legally then none. I would say that the dealer will follow the correct *procedure and make sure that they give you the right information to update the relevant departments (insurance included). This is what happened to my friends mum when she had her engine replaced in her Tig (put petrol in a diesel). Aside from VW replacing the engine under warranty (go figure) they made sure she had the right information to update the DPI (or whatever you call it in your state) and her insurance company (not that I think most insurance companies take the Engine # down).
    Feb 2009
    The rattling I'm getting is only brief at startup while the tensioner oil pressure comes up but has become more apparent since the last service about 2,000km ago..... I thought the oil filter had a non return valve in them to reduce the chance of the oil draining back into the sump, it should hold it's pressure......
    I went down the coast today (good hour long run) then stopped for 30 minutes, even after that short stop the tensioner had lost it's oil pressure and rattled briefly on startup.... never used to do that!!
    Tiggy 125TSI, 6 speed manual, tints, comfort pack.
    Adelaide hills, SA
    Get it checked ASAP.
    Sep 2011
    Townsville, Nth Qld
    Re: CAM chain tensioners failing..... TSI engines.
    Yuk, not good news So I presume Tigs built 2011 on should have had this corrected at the factory?
    Sent from my PadFone 2 using Tapatalk 2
    2011 147TSi 7spd DSG Reflex Silver, 18" New York Alloys, Leather with MDI, ECB Nudge Bar, Viezu Tune (Work in Progress), Eibach ProKit Springs, SuperPro Poly ALK & Rear Trailing Arm Bushes, H&R 26mm Rear ASB and Whiteline HD Adjustable End-Links, VAR Design 3" Downpipe, Sprint Booster, Auto-Polar FIS+ Advanced Module, GTI Sports Pedals, Flappy Paddle Strg Wheel, LED fogs as DRL, chrome blingy bits
    Feb 2009
    Tiggy1, apparently engines built from June 2010 onwards have the version2 update tensioners in them...... yours should be fine....
    Sep 2011
    Townsville, Nth Qld
    Phew, that‘s a relief - thanks
    Hope you can get yours sorted while still under warranty!
    Arrawarra
    Further to this & after 1 more quick visit to the dealers to resolve a hideous scraping sound when cornering (turned out to be a slightly bent backing plate behind LHS front rotor, probably the tow-truck drivers fault), everything seems to A++ now! Have done 1000k's on the new motor & about to move interstate (Newcastle) so want it to be good before i leave Melbourne...
    The only strange thing: You know that sound when you turn the key on, but don't start the engine (TSI) - sort of a 2 second "zsshhhhhhht", not sure exactly what it is, fuel pump maybe? Well, my car now makes that sound sometimes merely by opening the drivers door! Without the key even in the ignition! Have noticed it happen half a dozen times in the last week & a half.
    Any ideas?
    Jun 2009
    Quote Originally Posted by MGV View Post
    Any ideas?
    Mine makes it when i open the door, maybe it was an update between 2009 and 2010
