Results 1 to 2 of 2
Thread: Bluetooth on a 2011 tiguan
    Nov 2020
    Hobart
    So I just joined the club with a 2011 Tig that has only done 70,000. Somewhat stupidly I didn't check if it had Bluetooth and just assumed it did. It has the rcd 510. What do I need to do/buy to activate Bluetooth. Depending on cost I'll either buy the modules needed or just plug a USB adaptor into the aux port. It's only for music and podcasts while I drive. Don't need actual phone functionality.
    Jun 2011
    Genuine Volkswagen 9W7 Bluetooth Premium Retrofit kit OEM 7P6035730 - AA Auto Parts
    Its a kit that should be plug VCDS code and play. The foam holder is velcro'd to the carpet under drivers seat. The carpet cutouts for the cables are already there. Mic goes along the RH A pillar to the console above the mirror. There should be a slot ready for that. Then you have coding to do.
    I got mine 6 years ago from www.carsystems.eu.
    There are two levels of Bluetooth you can get. hi and low. High (9W7) gives you bluetooth audio streaming and steering wheel controls.
    VW Watercooled info here
    Install 9w2/9w7 Bluetooth
