Results 1 to 10 of 43
Thread: Best way to fit a full size spare in the boot
Threaded View
  1. #3
    Securing the wheel is easy with a longer bolt - using M8 threaded rod, nut and wing nut like the one on the left:
    If you keep the original rear floor, and let it sit 70mm higher, you either need to relocate the side pins that secure the front of it, or extend the pins. I tried the latter but it's a bit cluncky - works OK but the two extensions I made up can fall off, and the tailgate just closes flush with the floor in an elevated position. I also used two velcro strips to hold down the back end but the velcro doesn't stick all that well to the Tig's carpet.
    The easiest solution is to remove the floor and foam and just have the wheel there. Maybe put a wheel cover on it, or cover it with a bit of canvas or utility carpet. All depends on what you put in your boot.
    Last edited by Phil G; 10-01-2013 at 09:31 PM. Reason: Accidentally deleted photos - hopefully restored
