Results 1 to 9 of 9
Thread: How fixed fault code 01499 -01495
    Jul 2022
    united States
    Hi guys
    anyone of you have got these fault code 01495 and 01499
    I have been getting these code since I change the halogen from light bulbs for Led bulbs .
    So, when I switch on the night light sometime I got these error.
    Thanks in advance for any advice.
    Mornington Peninsula, VIC
    You need to turn off the cold bulb diagnostics or get resistor packs to trick the BCM into thinking your bulbs are not out.
    Or you could also switch your globes to "CAN BUS compatible LEDs"
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Jul 2022
    united States
    Ok copy that. So you know how to turn off the cold bulb diagnostics.
    What scan tool do you have, VCDS, ODB11 etc? it will depend on your BCM part number on how to turn it off.
    Jul 2022
    united States
    Hi MIG
    I use VCDS but I don’t know the BCM part number.
    I am not and expert with this electronic cars. But I do as much as I can. 😺
    Jul 2022
    united States
    This is the products specification 7
    input wattage 36 watts
    operating voltage DC 12-24V
    luminous Flux 3800LM/bulb
    color temp 6000K
    light source custom flip chip
    VW Tiguan 2016 S
    If you do an autoscan with VCDS and post it, we can work out what needs to be done.
    Jul 2022
    united States
    VW Tiguan 2016 S
    Jul 2022
    united States
    Here are the fault codes with description. I hope they work MiG . See ya ��
    VW Tiguan 2016 S
