Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Battery Drain Test - Suspect
    Dec 2008
    Sydney/Canberra
    With the vehicle locked, and left to sit for over 20mins?
    Jan 2010
    Melbourne,Victoria
    Quote Originally Posted by Umai Naa!! View Post
    Hi Umai,
    We tested about 10min, car locked with alarm on. It hovers between 0.85A and 0.86A.
    Cheers,
    XTX
    Dec 2008
    Sydney/Canberra
    You really need to do it over a longer period.
    As I alluded to earlier, it takes around 20mins for all the control modules to go into their 'sleep mode'. You'll see this almost immediately on whatever device you're using, to measure the current draw. It should drop down to around 0.2A.
    Jan 2010
    Melbourne,Victoria
    Hi Umai,
    I see. Could you please advise what kind of devise I need to do the test? Will a simple multimeter do the trick? Thanks.
    Cheers,
    XTX
    Dec 2008
    Sydney/Canberra
    Yeah, a multimeter would work. Even better if it had on inductive pick-up, or current clamp.
    Jan 2010
    Melbourne,Victoria
    Thanks Umai, I think the RACV guy used current clamp. Will try to get one over the weekend.
    Adelaide hills, SA
    I did have one come to me around 2009, that was virtually brand new. Had a faulty Convenience module in it, that kept 'waking up' once the CAN network went to sleep.
    If you watched the current draw, it'd gradually drop down to 0.2A after 20mins, once the CAN network went to sleep. Then BAM, the CCM would wake up, and start drawing huge current.
    Don't you mean 0.02A or better still 20mA? Anything over 0.1A (100mA) will flatten the battery especially the aged ones.
    The 0.2A will flatten your battery over the weekend if you don't use your car.
    Dec 2008
    Sydney/Canberra
    Yes, correct.
    Small error on my part.
