Battery Drain Test - Suspect
Hi,
My Tig's battery finally died after 6.5 years. Unfortunately, it happened in my local shopping mall car park, so I ended up getting the battery from RACV. The RACV technician did a test on my Tig and said that the battery was draining at 0.86A with the alarm on. He said it is supposed to be less than 0.45A, hence I need to get my car checked by car electrician. Would apprecaited if the experts in this forum can advise if his diagnostic is correct. IF yes, where is the best place I can get my Tig checked out.
The RACV technician also don't seem to know about the "airbag fault" issue after changing the battery. He said that it another thing I need to get it look at by someone else, not him. So I will get it reset when I get my Tig into the next service.
Thanks in advance,
XTiguanX
- You may not post replies
- You may not edit your posts
Forum Rules
