Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: AVC-9000 Tig install
  1. #21
    Apr 2009
    Canberra AUST
    Quote Originally Posted by Arctra View Post
    I'm interested to know how well this plays with the Park Assist feature. On the RNS510 the display of the vehicle and object positions in relation to the various sensors is great. Anyone know if it'll be the same with this unit?
    Park Assist uses the MFD in the middle of the dash... so Park Assist should still work.
    The issue would be with Optical Parking Sensors (front and rear sensors visual display) as that DOES use the RCD / RNS 510...
    my guess is if you use any head unit apart from the official VW ones - you would loose that functionality.
    Only a guess - happy for someone to contradict me.
  2. #22
    Mar 2009
    How to get the Tiguan Radio out!
    Has anyone opened up the dash of the Tiguan to install this new Radio?
    I've seen other threads where the first step is to remove the grille on the top of the Golf/Jetta dash. But the Tiguan seems to have a moulded in tray up there that doean't come out.
    Ideas?
    TDI tiguan in the drive. ParkAssist, comfort, fogs
    Service every 15,000, new fault code every 7,500km
  3. #23
    Dec 2008
    Alexandra, New Zealand
    Quote Originally Posted by Sanman View Post
    Ideas?
    if you go onto Vortex there's a "how to" on upgrading to a RCD510 by Rocc from Jamaica. There's also lots of other threads on updates, changes etc to the radio set up.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
  4. #24
    Nov 2008
    QLD
    Ideas?
    basically it's a 5 minute job:
    Firstly, remove the two black plastic bits sitting beside the hazard switch (one is a blank, the other has slots for your credit cards!). I used a knife blade to do this.
    You'll then see some screws behind these which allow the surrounding to come off with some gentle persuasion. There are tabs all around it that hold it in place, just work it off carefully from the lower sides. All the air vents and stuff come with it, so just be careful when pulling it out. I left everything connected and just swung it up onto the top of the dash (although I might have disconnected the hazard switch wiring just to get it to swing up?)
    When you get this off, you'll see 4 screws holding the existing stereo in. Unscrew these and pull it out! Done.
    Just out of interest, the Tig has 2 aerial connections - FM and AM. If you are replacing the head unit, you might want to get the adapter to connect the two together. Otherwise, just make sure you use the FM one.
  5. #25
    Mar 2009
    Thanks for the quick replies guys - it was the credit card holder removal step that I'd missed. I'll give it a try tonight.
    EDIT Well, that was easy, 20 minutes from start to end. I still have the GPS antenna loose, as I want to check its best performance before I buried it under the dash. No referring to manuals, just plug everything in where they fitted.
  6. #26
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Reversing Camera
    Can anyone that has this unit answer a question to do with the reversing camera for me? Does the unit automatically flick to the reversing camera when a signal comes through from the rear camera? Or do you have to select it via one of the buttons?
    The reason I ask is because I have a camera installed at the moment, but I've powered it from the boot 12V socket as I like the idea of an "always on" rear camera. I'm thinking this might be a problem with the AVC unit though if it automatically switched to rear camera when a signal comes through as I'll never be able to see anything else. I'm reluctant to power the camera from the reversing lights as I do like having the blind spot behind the car in view whilst driving (acts as a secondary rear-view mirror).
    Would appreciate any responses.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
  7. #27
    Dec 2008
    If you DO power it off the reversing lights make sure you do it through a relay (still running the power from the boot socket) , otherwise the Tig's "brain" will start sending out fault messages to mess up your day !!
    Derek
    Alexandra
  8. #28
    Nov 2008
    QLD
    sorry, don't think you can have it both ways. The unit will switch on automatically as soon as it gets a signal from the camera. Even if the unit is powered off, it will switch itself on and then off again after you disengage reverse. There's no other option for an additional camera input that could be selected from the unit itself.
    The only way around it would be to run a separate power switch to the camera that you could operate remotely from the drivers seat. Not hard to do, just a bit of extra wiring. That way, when you flicked it on the unit would switch to rear camera view. Music still continues to play, but you lose all functions (volume etc).
  9. #29
    Dec 2008
    IF you have it powered somehow off the reversing sensors (assuming you have those and are using a relay as discussed earlier) you could switch it on and off with the sensor switch BUT that won't switch on over something like 15kph.
    Derek
    Alexandra
