Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: auto hold
    Aug 2009
    canterbury, vic
    auto hold
    has anyone been using the auto hold feature in a Tiguan?
    there's seem to a soft high pitch sound when I turn on my "auto hold". it can be heard when the it is in use of course (idling or stopping at lights).
    anyone experiencing the same issue?
    Silver Tiguan
    Basic Rocks
    Jul 2007
    Canberra
    Probably the motor that drives the handbrake mechanism. I don't really use auto hold but I'll check next time I do. Is it the same sound as when you turn the hand brake on manually?
    Forever blowing bubbles.
    Mar 2009
    It would be the motor pulling on the handbrake that you hear, though I am surprised you can hear it above the idle.
    Its a clever mechanism, though pointless in an auto. In fact, it made take off a little jerky when I've played with it.
    I assume it will become more relevant as a roll precaution when idle-stop versions are released (my guess - no insider info here)
    EDIT: no motor - refer below, still some tricks the Tiguan is revealing
    TDI tiguan in the drive. ParkAssist, comfort, fogs
    Service every 15,000, new fault code every 7,500km
    Dec 2008
    Alexandra, New Zealand
    HAte to say it guys BUT the handbrake isn't activated with the auto-hold, it's all done with the ABS. If you try you'll notice that you don't get the rear "jacking" and releasing as you would with the handbrake. All that happens is that when you've stopped the ABS "holds" the brake setting as it is. So, not sure what you can hear (I don't hear a sound using auto-hold in mine) but it isn't the handbrake motor.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Nov 2008
    QLD
    Derek's right, it's the ABS that holds the wheels, that's why some people complain about the creaking sound (seems that the brakes hold at the pressure you applied when you pulled up, so if you didn't push down hard enough, the brakes may not quite be holding - or only just). Mine makes a small noise as I pull up and then when I take off and the brakes are released.
    Maybe try pushing your foot down harder when you pull up and stop - then see what happens.
    Jul 2007
    Canberra
    Good info Derek, I just assumed it worked on the hand brake, I think i've only used it once to make sure it worked
    Nov 2008
    QLD
    Quote Originally Posted by Pullstarter View Post
    I use it all the time, makes for quicker getaways
    Apr 2009
    Canberra AUST
    Can't say I've heard any noise of mine.
    I use it quite regularly in traffic... and it is great!
    2009 147TSI Tiguan, Deep Black Pearl Effect, Black Leather, Sunroof, RNS510, Bluetooth, and MDI.
    Delivered 22 May 2009
    Aug 2009
    North Coast, NSW
    am i correct that you have to turn the auto-hold on each time you get in the car, if so do you think there would be any drawback in being able to have it on all the time?
    Apr 2009
    Canberra AUST
    Yes you have to engage it every time you turn the car on.
    Is a shame there is no default ON
