Results 1 to 10 of 39
Thread: auto hold
advanr auto hold 22-08-2009, 05:10 PM
Pullstarter Probably the motor that... 22-08-2009, 07:56 PM
Sanman It would be the motor pulling... 22-08-2009, 10:31 PM
NZTiguan HAte to say it guys BUT the... 23-08-2009, 01:27 PM
clip Derek's right, it's the ABS... 23-08-2009, 03:58 PM
dogbowl Auto-hold is addictive. I'm... 02-10-2010, 12:41 PM
ahyew78 I had that soft high pitch... 01-10-2010, 03:39 PM
Transporter See the post above yours.:)... 10-10-2010, 07:31 AM
ChrisJ I like the autohold function,... 10-10-2010, 09:03 PM
Tigga1 Hi Chris (or anyone else),... 11-10-2010, 09:21 AM
ChrisJ Its in the MFD menu, scroll... 11-10-2010, 06:39 PM
Transporter This may help to explain some... 11-10-2010, 07:27 PM
blutopless2 only use it on really steep... 11-10-2010, 08:35 AM
RSanti How would you know if the... 09-06-2017, 09:14 PM
MGV The light stays on to... 12-06-2017, 11:25 AM
RSanti Alright I got it. Thanks... 12-06-2017, 03:45 PM
    Aug 2009
    canterbury, vic
    auto hold
    has anyone been using the auto hold feature in a Tiguan?
    there's seem to a soft high pitch sound when I turn on my "auto hold". it can be heard when the it is in use of course (idling or stopping at lights).
    anyone experiencing the same issue?
    Silver Tiguan
    Basic Rocks
    Jul 2007
    Canberra
    Probably the motor that drives the handbrake mechanism. I don't really use auto hold but I'll check next time I do. Is it the same sound as when you turn the hand brake on manually?
    Forever blowing bubbles.
    Mar 2009
    It would be the motor pulling on the handbrake that you hear, though I am surprised you can hear it above the idle.
    Its a clever mechanism, though pointless in an auto. In fact, it made take off a little jerky when I've played with it.
    I assume it will become more relevant as a roll precaution when idle-stop versions are released (my guess - no insider info here)
    EDIT: no motor - refer below, still some tricks the Tiguan is revealing
    TDI tiguan in the drive. ParkAssist, comfort, fogs
    Service every 15,000, new fault code every 7,500km
    Dec 2008
    Alexandra, New Zealand
    HAte to say it guys BUT the handbrake isn't activated with the auto-hold, it's all done with the ABS. If you try you'll notice that you don't get the rear "jacking" and releasing as you would with the handbrake. All that happens is that when you've stopped the ABS "holds" the brake setting as it is. So, not sure what you can hear (I don't hear a sound using auto-hold in mine) but it isn't the handbrake motor.
    Derek
    Alexandra
    2022 R-Line Golf Mk8 in Kings Red Metallic
    Previously 3 Tiguans 2008, 2013, 2017
    Nov 2008
    QLD
    Derek's right, it's the ABS that holds the wheels, that's why some people complain about the creaking sound (seems that the brakes hold at the pressure you applied when you pulled up, so if you didn't push down hard enough, the brakes may not quite be holding - or only just). Mine makes a small noise as I pull up and then when I take off and the brakes are released.
    Maybe try pushing your foot down harder when you pull up and stop - then see what happens.
    Jul 2007
    Canberra
    Good info Derek, I just assumed it worked on the hand brake, I think i've only used it once to make sure it worked
    Apr 2009
    Auto-hold is addictive. I'm used to it, and notice if I forget that it is a nuisance idling forward at a red light (auto). it is possible for it not to grab sometimes, if you don't depress the brake pedal properly.
    _______________
    125 TSI Auto, SunRoof, Park Assist, Lux Pack
    Apr 2010
    Campsie NSW
    i actually have the auto-hold on all the time. i set it up through the MFD. No need to VAGCOM it..
    Sep 2010
    Quote Originally Posted by advanr View Post
    I had that soft high pitch sound when I turn on Auto Hold as well, but I have to turn the volume right down to hear it.
    As I was having some issues with my gearbox, I just brought my car back to the dealer for them to have a look. While I was there, I got the mechanic (probably still an apprentice) to listen to it and he was saying its comes from electronics that was being activated. He said he has never heard it in a Tiguan before but its a common problem in the Polos.
    I was thinking does Polo have Auto Hold? They have Hill-Start Assist which probably has the same working mechanism???
    125TSI | Mountain Grey | 6SP Automatic | Leather | RNS510 | Rear View Camera | Comfort Package
    Adelaide hills, SA
    You can disable it again in MFD.
    Sent from my HTC Desire using Tapatalk
