Results 31 to 39 of 39
Thread: auto hold
  1. #31
    Aug 2006
    Far North Qld
    Quote Originally Posted by aussietig View Post
    Anyone notice with their Auto Hold that after say 5 - 10mins, it sort of releases a bit and car feels likes it's moved probably a couple of millimetres?
    Is this normal?
    I've noticed that if you don't break reasonably forcefully at time of stopping, sometimes there is a bit of creep...a simple push on the brake pedal fixes it...
  2. #32
    Nov 2008
    QLD
    it will only hold it for so many minutes, then it will apply the handbrake - might be getting just to that point.
  3. #33
    Mar 2011
    Gold Coast QLD
    Anybody know if the auto hold function disengages the DSG? In other words, if I'm stuck in a traffic jam and using auto hold am I better to snick it into neutral for a prolonged stop or just leave it in drive? Thanks!
  4. #34
    Wollongong, NSW
    No need to stick it in neutral
    You're thinking about the DSG all wrong. Its not an automatic gearbox
    Its basically a dual clutch manual gearbox.
    Officially its "an electronically controlled dual clutch multiple-shaft manual gearbox, in a transaxle design - without a conventional clutch pedal, and with full automatic or semi-manual control"
    So when at a dead stop the DSG basically has it in neutral or "engages the clutch" like you would in a manual
    Thats why there is that slight delay to kick into gear when you accelerate
    2011 Tiguan | 125TSI (5N) | Deep Black | DSG (7-speed) | Launch Control | 4Mo | Fog | Comfort | Bluetooth | MDI (USB + iPod) | Roof Bars | Rear Sensors | Floor Mats | First Aid Kit
  5. #35
    Mar 2011
    Gold Coast QLD
    Quote Originally Posted by Vince_S View Post
    Thanks for clearing that up for me...us old timers have a bit to learn!
  6. #36
    Nov 2008
    QLD
    you can stick it in neutral though as that release the clutches. Leaving it in Drive is sort of the same as leaving a manual in gear and keeping your foot on the clutch.
  7. #37
    May 2017
    How would you know if the brakes was already release after take off in autohold? The light wont shut off and im afraid that the brakes might burn. Is this normal? there's a feeling that the brake stil bites after take off.
  8. #38
    Arrawarra
    The light stays on to indicate that the autohold function is still active, for the next time you stop on a hill. The function can be active, without 'holding'.
    You could find a quiet street that had a very slight gradient, with autohold active & brake to a complete stop. Then take off slowly so you are just doing about 2 or 3kph & slip it into neutral, & ensure you continue to coast slowly?
  9. #39
    May 2017
    Quote Originally Posted by MGV View Post
    Alright I got it. Thanks heaps
    Update: i did exactly what you mentioned and the tig coasts slowly without "holding" the brakes
