Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: APR Stage II + CAI + APR Exhaust System
    Feb 2014
    I currently have the Stage 1 APR upgrade on my 132TSI Pacific Tiggy. I have to say this is the best purchase I've ever made for this car. World of difference. I am wondering if anyone has done the Stage II APR upgrade? Compared to the Stage I APR upgrade is it worth it? Is there a noticeable difference following an upgrade to Stage II if I already have Stage I?
    The Australia APR website is closed and it was much more informative and relevant than the American website.
    Mar 2015
    Torrens ACT
    In the past I have done everything but replace the turbo, Stages 1, 2 and 2.5.
    With my wife's R-Line We have just incorporated Stage 1 and the DSG software - more than enough.
    Therefore, IMHO, the best bang for the buck is what you have i.e.Stage 1 go further with Stage II and there are differences, certainly in the sound department and some in the performance department. It then becomes a reasonable question as to whether the drivetrain needs 'adjusting' - DSG, brakes, suspension and on it goes.
    Stage II onwards the resale declines as does the market of people willing to purchase a more highly modified car.
    At the end of the day a Tig is a pseudo SUV with van like dimensions and Stage 1 should be more than enough to go quickly but retain some of its character.
    Dingah
    Jun 2009
    I have Stage 2 and to be honest, the gains are nowhere near as big as the Stage 1 upgrade.
    The downpipe allows the power to come on a bit earlier and stay on a bit later and you do get a 20kw or so bump but for day to day driving it isn't really going to make a lot of difference.
    Feb 2014
    Well I should add mine is the 6sp Manual. So I guess upgrading to the K04 would make a massive difference (Is this Stage 3?). My question is would the other stock components, internals, clutch/gearbox etc be able to handle this additional power. At this stage I am very happy with the Tiggy at Stage 1 but just want a bit more.
    Since you have the Stage 2 upgrade, does it make a massive difference in the accoustics? I kinda don't want a bogan-mobile either if you get what I'm saying haha.
    Jun 2009
    I have the 6 speed manual as well.
    Stage 1 = ECU remap.
    Stage 2 = Downpipe (Air intake optional)
    Stage 3 = Turbo upgrade (K04 or other)
    I have a standard rear exhaust system on and the car is slightly noiser than standard but nothing bogan'y.
    Stage 3 is where you need to start loking at internals and other components to be upgraded which is why i haven't bothered to go any further.
    If you want a bit more power than stage 1 then stage 2 is a good bump but you end up applying the law of diminishing returns after Stage 1.
    Dec 2012
    Sutherland Shire, Sydney
    I purchased a Skoda Octavia with the 147 TSI engine
    I was not overly impressed with the performance so I had it flashed with stage 1
    When I picked it up I certainly noticed that it had more pep but it was nothing to write home about
    I drove it home and parked it without much fuss
    Over the following weeks I realized the top end (over 6k) pulling power was actually a little down on the stock tune
    A month later I took it back for the stage 2 program and dump pipe
    I picked the car up and was totally blown away by how hard it pulled - I went for a 3 hour drive - wife phoning to complain "where are you"
    The low end torque, the strong pulling power from mid range to red line and the wide power band all blew me away
    The stage 2 tune is a huge step forward and far more rewarding than stage 1
    Maybe its different on the tiggy with the 132 TSI
    Jun 2009
    Quote Originally Posted by Martin View Post
    The base model tiguan stage 1 upgrade is massive because you start from 125/132 so you get a 22kw boost over the GTI/vRS due to the tiguan being detuned from the factory.
    The tiguan is also heavier and has the AWD system which means you end up with less of a boost with the Stage 2 upgrade compared to the GTI/vRS.
    Feb 2014
    Quote Originally Posted by team_v View Post
    Ok so you have Stage 2 then? Did you do the down pipe only or did you do the intake as well?
    Jun 2009
    I got the intake at the same time as i did the stage 1 ecu remap.
    It basically makes very little difference but it sounds better (intake vacuum) and clears up the engine bay.
    The car is now Stage 2 as i have the downpipe on.
    Mar 2015
    Torrens ACT
    On a GTi did Stage 2 with downpipe and hi-rate fuel pump tried the intake on and off and it made no discernible difference to the power and just added to the noise so it came off. Bottom line for the amount of work and the cost involved the additional increment in power/performance from Stage 1 to Stage 2+ was just not worth the money.
    Standard to Stage 1 is a far, far better bang for the buck. I would put DSG software as a better investment than Stage 2.
    Dingah
