Hey all,
Was just wondering if anyone has had their Tig dyno'd? If so, you would have to use an awd dyno but would the 4motion system give you funky readings because of the torque transfer etc?
Simon
Forever blowing bubbles.
I'm seriously considering getting my Tig Dyno'ed at the Sydney Dyno day Fuzion has organised. Will be interesting to see the results and whether the AWD makes a difference.
Tiguan TDI, 6spd Tiptronic Auto
Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
Avg 7.63L/100km over 189,000kms
Actually you don't need an AWD dyno for the Tiguan. Pull a fuse out (or unclip a connection) and its FWD only ..... thats the benefit of the 4Motion system since its only a "make believe" AWD ....
Guy knows which one .... so some info here Guy please ....
I believe running on a AWD dyno will only confuse the dyno as the drive to all 4 wheels is not constant or the same.
For Dyno testing it's fine to unplug the Haldex unit converting it to FWD.
To the best of my knowledge, there is no fuse to pull on these cars, but unplugging it is a 2 minute job under the car.
You need to clear fault codes after unplugging it.
Saves any of the dyno associated kick in / out of the AWD system.
Thanks for the info guys. Only problem is if it throws codes will I be able to drive it to my mechanic to clear them after (no idea if the dyno place would have vagcom) or will it just not go?
