Results 1 to 10 of 15
Thread: Anyone consider a brake upgrade?
    Mar 2010
    Soutbank, Victoria
    I was wondering if anyone has considered a brake upgrade for their Tig? Either pads or new rotors and calipers? I would appreciate if anyone has done it if they could share their experiences. I think the standard brakes are pretty good but at times I wish they had a bit more grab and let's face it, they don't really look the part especially if you have bigger rims on the car...
    Jun 2009
    Mine grab like nothing else, almost put myself through the windscreen if i hit them too hard.
    I was considering a brake upgradfe initially but now i will wait until the rotors are worn down before i go that path.
    I would be getting some EBC pads when they wear down but don't know if that increases bite, it may just reduce brake dust.
    ECStuning has brake kits which may be of some help but i don't know how much bigger you can go really.
    Nov 2007
    Remember that the Tiguan already has the GTI brakes (312mm). So upsizing the rotors or calipers is really not necessary for the environment a Tig lives in.
    I'm planning the following ....
    EBC Red pads (no fade under even track use)
    Cross-drilled rotors (still 312mm so purely for looks through the alloy wheels)
    Jun 2009
    I was considering the corss-drilled rotors for when mine wear down but i have heard that the holes get clogged up with brake dust quite easilyy so if i do upgrade i will probably opnly do slotted rotors.
    EBC Red pads are on my list when the pads need replacement.
    I believe a VWWatercooled site sponsor sells them.
    Mar 2010
    Soutbank, Victoria
    I found my brakes really grabbed when the car was new but after 6000+K's they fade a bit on hard driving... maybe I will just look at some EBC red pads...
    Adelaide hills, SA
    Where ever I could, I always used slotted rotors on our cars, so I will try to get slotted for Tig as soon as it arrives. Current car Forester got slotted rotors when my kids started to drive. The braking characteristic with slotted discs is always the same and the brakes don't fade. Another cheaper brake upgrade would be braided brake hoses, just make sure that your car is street legal and your insurer is OK with that mod.
    Mar 2009
    Guatemala Central America
    Sharkie,
    By any chance you know if they Tiggy and the GTi share the same caliper? I would love to get a hand on a 4 piston caliper BBK
    Mar 2009
    Well if somebody has some interest on this the front piston caliper diameter on the AWD Tiggy is 57mm and the GTi is 54mm so the BBK for the GTi don't work perfectly well.
    I'm in the middle of convincing a BBK manufacturer to make on for my wife's tiggy.
    Would anybody be insterested on a BBK? Drop me a PM please
    Nov 2008
    QLD
    Quote Originally Posted by tanehy View Post
    I was wondering if anyone has considered a brake upgrade for their Tig?... and let's face it, they don't really look the part especially if you have bigger rims on the car...
    No, not unless i was going to track it -which although I'd love to see some faces out there, I wouldn't. so maybe something like this if the looks are a concern:
    Big Brake Caliper Cover Kit.
    much cheaper
    Feb 2013
    Bathurst NSW
    I am considering a brake upgrade on 2011 Tiguan 147tsi, APR stage 1. Recently i had the need to pull up in a bit of hurry from a fairly high speed the result was over heated brakes and warped rotors. I would hate to thing what a lap of Mt Panorama would do to them.
    If you tend to drive a bit harder than most then Brembo have an upgrade but you need at east 18 inch rims i think which makes for an expensive mod. If anyone has done other upgrades that are considerably better than originals and cheaper than Brembo option i would love to here about it.
