Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Anyone consider a brake upgrade?
    Jun 2013
    Quote Originally Posted by scottics View Post
    I am considering a brake upgrade on 2011 Tiguan 147tsi, APR stage 1. Recently i had the need to pull up in a bit of hurry from a fairly high speed the result was over heated brakes and warped rotors. I would hate to thing what a lap of Mt Panorama would do to them.
    If you tend to drive a bit harder than most then Brembo have an upgrade but you need at east 18 inch rims i think which makes for an expensive mod. If anyone has done other upgrades that are considerably better than originals and cheaper than Brembo option i would love to here about it.
    Yes I do but it would not be a near future upgrade for me. Still I like to consider options available for Tigs. one options I have in mind was AUDI TTRS brakes. I think they are made by brambo and some times second hand kits come out in eBay as owner upgraded their brakes. Only problem see with this option is you need to at least have 19 inch wheels to clear callipers.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Jan 2011
    Brisbane - QLD
    depending on the budget, i would start with replacing front rotors with slotted discs, high temp brake fluid (i use motul rbf600), remove the dust shields and use good pads with high MOT.
    i have used ebc redstuff and the pads crumbled after a day on Marulan track with stock calipers and the red paint turned black!
    i have used hawk hps and did not find them suitable for my needs and experienced brake fade (i should have known as these pads are not suitable for track use at all).
    good info here for pads selection:
    Zeckhausen Racing
    i have been using stoptech street performance pads (with MOT of 1300 degrees F) and have not had any fade on track sessions over the last 2 years (big contributing factor is front 330mm Stoptech BBK).
    imo, BBK gives the biggest benefit no fade in repetitive hard braking.
    with my Tiguan, 1/2 hour on Lakeside enthusiastic cruise aka Happy Laps did show some brake fade but a few laps of cooling runs the brakes went back ok.
    MINI Cooper S Clubman - FWD
    Dec 2013
    Good option is the scirocco front brakes. 345mm discs. That's more than likely what I'm doing if the vwr bbk doesn't fit behind my wheels.
    Jun 2009
    Quote Originally Posted by stiffy86 View Post
    345 is quite big, you are going to have to run a minimum 18" wheel to fit those suckers aren't you?
    That is my main reason for not going with a BBK and instead going for upgraded brake fluid and if i want more i can get braided lines.
    Dec 2013
    Quote Originally Posted by team_v View Post
    I'd assume so. I know some 17's will just fit over the golf r brakes and these are larger.
    I'll be running a 19
