Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Aluminium / stainless steel pedals
    London
    This is my set up. The gas and brake pedals are OEM spec on my 2011 R Line. The dead pedal was from eBay and I modified it to include the rubber inserts because it just comes as a CNC milled plate.
    Here is one example of where you can purchase a similar one from.......
    VW GOLF MK5 MK6 MKV NEW RLINE FOOTREST WITH BLACK RUBBER BACKING R32 TURBO | eBay
    2011 Candy White Tiguan R Line 170 TDI DSG | Pan roof | Park assist & RVC | RNS 510 | MDI | LED's | 20" RS5 Wheels| Bi-xenons & AFS | Front & Rear footwell lights | Door warning & puddle lights | Mirror puddle lights | LED Tail lamps | Eibach Pro-Kit Springs
    Jul 2010
    OK so the Mk5 GTI obviously had an OEM RHD aluminium dead pedal.... will keep looking as I'd like to have a complete matching set.
    Nah they're not. No OEM for RHD.
    Mine were bought off a UK seller on eBay and without the rubber insert (if you look carefully).
    I would go for the eBay seller that Naresh has provided a link to. Definitely look the part.
    They do sell normal ones without any GTI or R logo, but with the rubber:
    http://www.ebay.co.uk/itm/VW-GOLF-BO...item27d41cfece
    But for a true OEM look, see if they can sell you one without the holes/pre-drill.
    I fastened mine just with strong glue.
    MY11 Tiguan 147TSI (SOLD)
    Sep 2012
    australia
    Quote Originally Posted by Naresh View Post
    saw your DIY thread before but the tiguan has a square finish for the footrest. the one you linked and installed has a arc shaped finished. although it looks decent enough maybe i'm just picky.
    MY12 132TSI Tiguan Titanium Beige| DSG | Tint | Park Assist | RNS510 | Bi-Xenon |Comfort pack | R pedals | 155 Chrome Bits
    Quote Originally Posted by Ramee View Post
    Also Tiggy got new pedals. I had to do throttle body calibration through VCDS to get her idling RPM correct after accelerator pedal install.
    Hey Ramee, mind telling us where you got your pedals from? Are these the same Tuning Fanatics ones? Do you remember if they came with OEM packaging/part#'s?
    And what was involved in doing the throttle body calibration?
    Jun 2013
    Yes! They are Tuning Fanatics ones. Even though they work and I am satisfied with the pedals they are not upto the original OEM quality standards.
    Bottom side of TF pedals
    After I installed the TF pedal car starts to idling high aroung 1200 rpm like you pressed the acc pedal a bit. So I had to follow TB calibration procedure in VCDS so that car ECU can relearn the the new idling positions. May be tuning fanatics pedal has its sensor values bit off from the OEM ones. Anyway TB calibration by VCDS software has solve the issue and car now works fine.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Thanks Ramee for your feedback and also for the part#
    I'll check out what my local VW parts guy can do and the parts he has available (and if it's the same).
    After I installed the TF pedal car starts to idling high around 1200 rpm like you pressed the acc pedal a bit. So I had to follow TB calibration procedure in VCDS so that car ECU can relearn the the new idling positions. May be tuning fanatics pedal has its sensor values bit off from the OEM ones. Anyway TB calibration by VCDS software has solve the issue and car now works fine.
    Good to hear that this can be adjusted if required.
