You might want to refer to page 2.
http://www.transport.qld.gov.au/reso...11_sept_09.pdf
Just a heads up!
I'm looking to retro fit driving lights to my Tig and would like t to be as close to a factory fitted one as possible.
NZtiguan's link to http://www.mytiguan.com/viewtopic.ph...+lights#p43062 doesn't seem to work anymore. So I'm unable to follow Derek's work.
The lights and wiring harness will probably sourced locally or from OEMplus, however according to the OEMplus website a highline CECM will be required, does anyone know if our Tigs already come with a highline CECM?
Foglamp - Front Kit [1T0941699CKIT] - $280.00 : OEMplus.com, Original Equipment
Also does a retro fog install need a different light switch or will the standard switch be fine? How much codeing is required and do VW service centers do this on request and what would be a reasonable charge?
Try this new link BUT you may have to "sign on" to myTiguan.com
Fog Lights - myTiguan Forum
Derek
Derek
Alexandra
2022 R-Line Golf Mk8 in Kings Red Metallic
Previously 3 Tiguans 2008, 2013, 2017
I actually thought you meant something like this....?
2010 Candy White TDI Auto, black leather, bi-Xenons + fogs, DVD plus other gadgets and gizmos to keep the kids quiet!
Hi
When I got mine I gave the dealer in the UK my VIN number and he made sure he got the right ones for my Tig but I'm sure there are only two different grills, one for the track and field (28º front) and one for the standard (18º front). ALL the Ausi and NA ones are 18º but some of the others World wide have the 28º front. Just make sure you get the right ones !!
Derek
Alexandra
Has anyone fitted large additional driving lights to their Tiguan either using a nerf-bar or a Uni-bar -numberplate bar?
I was curious about particularly the stiffness; non vibrating lights....price, supplier complications etcetera.
I've some Osram 65w Rallye globes on the way but expect the real solution to improve visibility in winding mountain roads will be either fitting the OEM fogs or additional lights, maybe both?
Can anyone describe to OEM foglight spead and how it infills the roadside beyond the low-beam light spread?
At highway speed on meandering roads on a clear night the std lights aren't too bad, add rain or tight turns and wombats/roos are too easily hidden on the road verge for my aging eyes.
OEM Foglights provide very little, if any additonal long range lighting. All they provide is some additional lighting very close to the front of the vehicle and slightly more to the side (but once again, very close to the front of the vehicle). ie more short range light than anything else.
Yes road verge lighting, say from 45-90deg, brightness and reach is what i'm curious about.
Aftermarket lighting will illuminate this area (and more) but is a clumsly installation. I was wondering, somewhat dubiously, if the OEM fogs might suffice in lighting while being neater and less costly.
