I wired up the Passat camera OK. Feeds fine off the rear wiper power, and it runs to the front using the 'spare' antenna coax (as the Waywell/AVC9000-1 unit uses only the whip antenna on the roof, not the rear glass antenna). Picture quality is fine after you apply the 'reverse camera' patch. For some annoying reason the radio mutes when in reverse.
My Camera is set constantly powered (the wiper motor has power when the ignition is on), although you can use the 'reverse light wire' that came with the camera to power it only in reverse. This not necessary, as the head unit turns on the camera picture when reverse is selected by monitoring the canbus. You can select the camera at any time though Source icons/buttons (keeps the kids amused)
So technically, all green lights, you can install a reverse camera by removing two screws and unclipping 4 pieces of trim on the tailgate.
The Passat Camera doesn't fit properly, and hangs down a bit low. Looks ugly.
I have ordered a Polo camera (like this
http://www.golfmkv.com/forums/showpo...postcount=4085) , and although this also does not fit quite right, I think it will be acceptable. Another week or two for the finished install.
